# What is thermal cycling stability?
**URL:** <https://forum.ofscn.net/t/what-is-thermal-cycling-stability/2456>\
**Created:** [July 30, 2026, 2:40pm UTC](https://forum.ofscn.net/t/what-is-thermal-cycling-stability/2456 "2026-07-30T14:40:39Z")\
**Post date:** [July 30, 2026, 2:40pm UTC](https://forum.ofscn.net/t/what-is-thermal-cycling-stability/2456/1 "2026-07-30T14:40:40Z")
If the jumper is repeatedly cycled between -40
°C and +150
°C daily, will its lifespan be reduced?
**Post date:** [July 30, 2026, 2:41pm UTC](https://forum.ofscn.net/t/what-is-thermal-cycling-stability/2456/2 "2026-07-30T14:41:10Z")
Daily temperature cycling between -40\ ^\circ\text{C} and +150\ ^\circ\text{C} will cause the lifespan of standard fiber optic patch cords to **drastically shorten, leading to direct failure within just a few cycles** ; whereas, professional-grade specialty high-temperature fiber optic patch cords that meet the requirements of this temperature range will maintain long-term stable operation throughout their designed lifespan.
The core physical mechanisms and material degradation reasons behind this are as follows:
### 1. Failure Mechanisms of Standard Fiber Optic Patch Cords Under High-Temperature Cycling
Conventional fiber optic patch cords (e.g., commonly used indoor G.652D or G.657 grade patch cords) are typically designed for operating temperatures ranging from -40\ ^\circ\text{C} to +75\ ^\circ\text{C} (or +85\ ^\circ\text{C}). Exposing them to a variable temperature environment of +150\ ^\circ\text{C} triggers the following critical issues:
- **Thermal Degradation of Jacketing Materials** :
The outer jackets (such as PVC, PE, or LSZH) of standard fiber optic patch cords, along with the standard acrylate coating on the fiber surface, rapidly soften, age, and oxidize at temperatures above 120\ ^\circ\text{C} . Once the fiber’s coating peels off or carbonizes, the bare fused silica glass fiber is directly exposed to the air, making it highly susceptible to brittle fracture due to moisture-induced crack propagation in microscopic fissures.
- **Macro-stress and Microbending Induced by Mismatched Coefficient of Thermal Expansion (CTE)**:
A fiber optic patch cord is a heterogeneous structure composed of multiple materials (silica glass fiber, polymer coatings, stainless steel metal hose/armor, ceramic ferrule, and epoxy curing adhesive, etc.). These materials have vastly different coefficients of thermal expansion (CTE). During drastic temperature fluctuations from -40\ ^\circ\text{C} to +150\ ^\circ\text{C}, inconsistent expansion and contraction rates generate immense alternating thermal stresses within the ferrule and along the fiber. This leads to microbending of the fiber, causing a sharp increase in optical loss, and potentially fracture at the root of the ferrule due to stress concentration.
- **Aging and Loosening of Connector Epoxy** :
The epoxy resin used inside ordinary fiber optic connectors (such as FC, SC, etc.) to fix the fiber and ceramic ferrule cannot withstand temperatures of +150\ ^\circ\text{C}. High temperatures cause the adhesive to exceed its glass transition temperature ( T\_g ), leading to failure of its physical properties, softening, and carbonization. When the temperature fluctuates drastically between -40\ ^\circ\text{C} and +150\ ^\circ\text{C}, the compromised adhesive can no longer hold the fiber securely, allowing the fiber to axially “recede” or “protrude” within the ferrule, resulting in end-face damage or connection failure.
### 2. The Solution: Choosing High-Temperature Patch Cords with Excellent “Thermal Cycling Stability”
To prevent shortened lifespan under repeated thermal cycling in the wide temperature range of -40\ ^\circ\text{C} to +150\ ^\circ\text{C}, patch cords must be designed for high-temperature resistance and thermal shock resistance across the entire assembly, from the fiber coating and outer jacket to the connector structure and adhesive.
For this application scenario, the professional-grade **[OFSCN® 200℃ Fiber Optic Patch Cord](https://www.ofscn.org/patch-cords/high-temperature-200.html)** designed by Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) is recommended. This product boasts an extensive operating temperature range of -200\ ^\circ\text{C} to +200\ ^\circ\text{C}, perfectly covering the operating environment and demonstrating exceptional “thermal cycling stability.”
**Technical Advantages Explained:**
- **Polyimide-Coated Fiber** :
Internally, it utilizes a unique high-temperature resistant polyimide coating on the fiber, preventing the melting and carbonization of standard acrylate materials at high temperatures and ensuring long-term mechanical protection for the fiber’s glass surface.
- **Seamless Steel Tube Full Metal Encapsulation** :
It features a 0.9\text{mm} stainless steel seamless steel tube protective layer. This all-metal construction is free from plastic aging and effectively withstands external tensile and compressive forces during high and low-temperature cycling.
- **Specially Designed High-Temperature Connectors and Adhesive** :
The connectors are encapsulated with special high-temperature resistant materials and epoxy adhesive rated for 200\ ^\circ\text{C} . This allows them to endure frequent thermal alternations without causing fiber fractures or slippage within the ceramic ferrule due to uneven stress.
The official standard images of this product are as follows:
 ![OFSCN® 200℃ Fiber Optic Patch Cord](https://forum.ofscn.net/uploads/default/original/1X/0d3d3e9df6438484a2bf68af9c1f4d177cac5ec4.jpeg)
 ![OFSCN® 200℃ Fiber Optic Patch Cord](https://forum.ofscn.net/uploads/default/original/1X/eff745ff12f8cc8cb270e0bc4603804754e47cf0.jpeg)
 ![OFSCN® 200℃ Fiber Optic Patch Cord](https://forum.ofscn.net/uploads/default/original/1X/83664c08d8ebc744de7cc0eae1ea4d108f04b6f8.jpeg)
Therefore, using specialized fiber optic patch cords rated for 200\ ^\circ\text{C} will not abnormally shorten their lifespan when subjected to daily -40\ ^\circ\text{C} to +150\ ^\circ\text{C} cycles. Conversely, employing conventional standard patch cords will result in a drastic reduction in lifespan, leading to failure due to material aging, increased microbending losses, or fracture within a short period.
