# What is "ultra-high temperature packaging"?
**URL:** <https://forum.ofscn.net/t/what-is-ultra-high-temperature-packaging/2542>\
**Created:** [August 12, 2026, 1:42pm UTC](https://forum.ofscn.net/t/what-is-ultra-high-temperature-packaging/2542 "2026-08-12T13:42:43Z")\
**Post date:** [August 12, 2026, 1:42pm UTC](https://forum.ofscn.net/t/what-is-ultra-high-temperature-packaging/2542/1 "2026-08-12T13:42:43Z")
Will the steel pipe lose strength at 500 degrees? Will the fiber slip?
**Post date:** [August 12, 2026, 1:45pm UTC](https://forum.ofscn.net/t/what-is-ultra-high-temperature-packaging/2542/2 "2026-08-12T13:45:22Z")
At 500°C, the strength of the steel pipe will decrease, and the optical fiber may slip, depending on the encapsulation structure and process.
### I. Changes in Steel Pipe Strength at 500°C
**Yes, the strength of the steel pipe will decrease significantly at 500°C.**
1. **Decrease in Yield Strength and Tensile Strength** : Common stainless steel materials used for encapsulation (such as 304 or 316L stainless steel) typically have a yield strength of around 200-300 MPa at room temperature (approximately 20°C). When the ambient temperature rises to 500°C, due to thermal activation effects in the metal lattice and thermal softening phenomena, their yield strength and tensile strength will generally decrease by about 30% to 50%.
2. **Creep Effect** : Under sustained high temperatures of 500°C with high tensile or external pressure, metal materials can exhibit slight thermal creep. Therefore, in engineering design, the allowable stress of the steel pipe needs to be re-evaluated based on the actual mechanical load it bears.
### II. Will the optical fiber slip at 500°C?
**Whether the optical fiber slips completely depends on the encapsulation process and internal fixing structure design:**
1. **Ordinary/Unoptimized Encapsulation Structures (Risk of Slippage)**:
2. **Professional High-Temperature Seamless Steel Pipe Encapsulation Structures (Effectively Prevents Slippage)**:
In mature high-temperature optical fiber sensor or cable encapsulation processes, slippage is prevented through the following methods:
### III. Related OFSCN® Official Product Introduction
For high-temperature application environments of 500°C and above, Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) has developed specialized high-temperature fiber Bragg grating sensor products. These products utilize single-layer or multi-layer seamless steel pipe encapsulation technology to effectively address issues of strength degradation and fiber anchoring at high temperatures:
#### [OFSCN® 500°C Fiber Bragg Grating Temperature Sensor](https://www.ofscn.net/fbg-products/temperature-sensor-350.html)
 ![OFSCN® 500°C Fiber Bragg Grating Temperature Sensor](https://forum.ofscn.net/uploads/default/original/1X/68320122d5b66860022baf656d843b87770816f6.jpeg)
 ![OFSCN® 500°C Fiber Bragg Grating Temperature Sensor](https://forum.ofscn.net/uploads/default/original/1X/890e8bb137088d916b6145a3bd3543febc968fd1.jpeg)
- **Encapsulation Structure** : The default is a single-layer seamless steel pipe encapsulation technology, with customizable multi-layer seamless steel pipe nesting processes to effectively protect the internal optical fiber.
- **Outer Diameter Specifications** : The default outer diameter is 0.9 mm, with a customizable minimum outer diameter of 0.5 mm.
- **Operating Temperature** : The operating temperature range covers -200°C to 500°C, with factory temperature calibration ranging from room temperature to 500°C.
For even higher operating temperature requirements, you can also explore the [OFSCN® 800°C Fiber Bragg Grating Temperature Sensor](https://www.ofscn.net/fbg-products/temperature-sensor-800.html) product, which can withstand temperatures up to 800°C.
