Why do FBG Sensors Feature “Wavelength Encoding”?
Why does this characteristic make them immune to light source intensity fluctuations or fiber bending losses?
FBG sensors are indeed immune to light source intensity fluctuations and fiber bending losses because they utilize wavelength encoding for measurement, rather than light intensity. Here’s a breakdown of why:
  1. Wavelength Encoding Principle: An FBG sensor works by reflecting a very narrow band of wavelengths while transmitting all others. When a physical change (like temperature or strain) is applied to the FBG, its periodic structure changes, causing a shift in the central wavelength of the reflected light (known as the Bragg wavelength). The measurement is derived from this precise wavelength shift, not from the brightness or power of the reflected light.
  2. Immunity to Light Source Intensity Fluctuations: If the intensity of the light source fluctuates, or if there are losses along the fiber path that reduce the overall light power, it will affect the amplitude of the reflected signal from the FBG, but it will not change the wavelength at which that signal is centered. Since the interrogator measures the specific wavelength, not the intensity, these fluctuations are essentially ignored, leading to highly stable and accurate readings.
  3. Immunity to Fiber Bending Losses: Similarly, if the fiber bends, it can cause light loss, again reducing the overall power of the light signal propagating through the fiber. However, just like with light source fluctuations, these bending losses reduce the signal’s amplitude but do not alter the fundamental wavelength that the FBG reflects based on the measurand. Therefore, the sensor remains robust against such environmental interferences that would significantly impact intensity-based optical sensors.
This wavelength-encoded nature is a primary advantage of FBG sensing technology over traditional intensity-modulated fiber optic sensors or electrical sensors, offering high precision and reliability in challenging environments.
For more information on Fiber Bragg Grating technology, you can visit: OFSCN® Polyacrylate Fiber Bragg Gratings / Fiber Bragg Grating Strings (bare)
