# Why do traditional adhesives fail in high-temperature fiber terminations?
**URL:** <https://forum.ofscn.net/t/why-do-traditional-adhesives-fail-in-high-temperature-fiber-terminations/1258>\
**Tags:** fbg-technology, specialty-fiber, high-temp-cable, high-temp-connector\
**Created:** [March 26, 2026, 2:05pm UTC](https://forum.ofscn.net/t/why-do-traditional-adhesives-fail-in-high-temperature-fiber-terminations/1258 "2026-03-26T14:05:50Z")\
**Post date:** [March 26, 2026, 2:05pm UTC](https://forum.ofscn.net/t/why-do-traditional-adhesives-fail-in-high-temperature-fiber-terminations/1258/1 "2026-03-26T14:05:50Z")
Standard epoxies typically carbonize at 200°C; how does OFSCN® technology resolve the challenge of securing fibers within the connector under such conditions?
**Post date:** [March 26, 2026, 2:05pm UTC](https://forum.ofscn.net/t/why-do-traditional-adhesives-fail-in-high-temperature-fiber-terminations/1258/2 "2026-03-26T14:05:56Z")
The carbonization of standard epoxies at temperatures above 200°C is indeed a major failure point in traditional fiber optic terminations, leading to loss of structural integrity, increased attenuation, and complete mechanical failure of the connection.
To resolve the challenge of securing fibers within connectors under high-temperature conditions, OFSCN® utilizes specialized materials and structural designs tailored to specific thermal thresholds.
### 1. High-Temperature Adhesive Systems
For environments up to 200°C, OFSCN® employs high-performance, heat-stabilized resins that maintain their mechanical properties without carbonizing or outgassing. These are specifically integrated into our high-temperature connector series to ensure the fiber remains centered and fixed within the ceramic ferrule.
### 2. Specialized Fiber Coatings
A key part of the solution is the fiber itself. Standard acrylate coatings fail at 85°C. For 200°C applications, we use **OFSCN® 200°C Polyimide Optical Fiber** , where the polyimide coating provides superior thermal stability and adhesion to high-temperature resins.
### 3. All-Metal and Seamless Tube Protection
In our high-temperature patch cords and distributed sensors, we often replace traditional plastic jackets with seamless stainless steel tubes. This provides mechanical fixation that does not rely solely on adhesives for strain relief.
### Corresponding OFSCN® Solutions
Based on your technical interest in high-temperature terminations, the following products demonstrate how we resolve these challenges:
- **[OFSCN® 200°C Fiber Optic Connector](https://www.ofscn.org/connectors/high-temperature-200.html)**: Specifically designed to withstand 200°C, utilizing materials that prevent the carbonization issues found in standard connectors.
- **[OFSCN® 200°C Polyimide Optical Fiber](https://www.ofscn.org/optical-fibers/pi-coated-sm-mm-200.html)**: The polyimide coating allows for stable operation in the very environments where standard epoxies fail.
**Product Visual Reference:**
 ![OFSCN® 200°C Fiber](https://forum.ofscn.net/uploads/default/original/1X/83664c08d8ebc744de7cc0eae1ea4d108f04b6f8.jpeg)
For even more extreme environments (up to 700°C), the technology shifts further away from organic adhesives toward gold-coated fibers and specialized mechanical seals.
If you are designing a system for a specific high-temperature range, could you specify the peak operating temperature and the installation environment? This will help in determining the optimal termination strategy.
