# Why is the demodulator the "anchor pin / cornerstone" of the system?
**URL:** <https://forum.ofscn.net/t/why-is-the-demodulator-the-anchor-pin-cornerstone-of-the-system/3074>\
**Created:** [October 19, 2026, 2:52pm UTC](https://forum.ofscn.net/t/why-is-the-demodulator-the-anchor-pin-cornerstone-of-the-system/3074 "2026-10-19T14:52:30Z")\
**Post date:** [October 19, 2026, 2:52pm UTC](https://forum.ofscn.net/t/why-is-the-demodulator-the-anchor-pin-cornerstone-of-the-system/3074/1 "2026-10-19T14:52:30Z")
Without accurate demodulation, even the best sensor is just a piece of glass, isn’t it?
**Post date:** [October 19, 2026, 2:53pm UTC](https://forum.ofscn.net/t/why-is-the-demodulator-the-anchor-pin-cornerstone-of-the-system/3074/2 "2026-10-19T14:53:19Z")
From the perspective of the engineering and physical architecture of optical sensing systems, this statement largely hits the mark.
### I. Division of Labor in “Encoding” and “Decoding” Physical Quantities
An FBG (Fiber Bragg Grating) sensing system forms a complete closed loop consisting of two main parts: **front-end passive encoding (sensors)** and **back-end active demodulation (interrogator)**.
1. **Role of the Front-End Sensor – Wavelength Modulation (Encoding):**
Fiber Bragg Grating sensors are based on the Bragg reflection principle, where the center reflection wavelength \lambda\_B satisfies the formula:
2. **Role of the Back-End Demodulator – Spectral Calculation (Decoding):**
The interrogator integrates a light source (broadband source or high-speed wavelength-tunable laser), optical filtering/spectroscopic components, a photodetector, and high-precision wavelength calculation algorithms. It is responsible for emitting light and collecting the reflected spectrum in real-time. Through precision peak-finding algorithms, it determines the current \lambda\_B and then converts it into calibrated physical data.
Without a demodulator or if the demodulator lacks sufficient precision, even though optical physical modulation processes are occurring within the fiber, the system cannot extract any quantifiable data.
### II. Why is the Demodulator the “Anchor” of the System?
In practical engineering systems, the demodulator typically determines the performance ceiling of the entire measurement chain:
1. **Benchmark Limit for System Resolution and Accuracy:**
The temperature sensitivity of Fiber Bragg Gratings is typically around 10\text{ pm/℃}, and the strain sensitivity is approximately 1.2\text{ pm/}\mu\varepsilon. If a demodulator possesses a wavelength resolution of 1\text{ pm}, the system’s theoretical limit resolution can reach about 0.1\text{ ℃} or micro-strain levels; if the demodulator’s internal temperature drift control is poor or it lacks a dynamic wavelength calibration reference, the entire system will experience systematic drift that cannot be corrected by the front-end sensor.
2. **Determiner of System Dynamic Characteristics:**
The front-end fiber material itself possesses extremely high dynamic response bandwidths for acoustics and strain. However, the frequency at which the system can capture vibrations or dynamic impacts (e.g., 10\text{ Hz}, 50\text{ Hz}, or 100\text{ Hz}) depends entirely on the demodulator’s sweep rate, detector response speed, and underlying data throughput capabilities.
3. **Multiplexing (WDM) Capability for Multi-Point Demultiplexing:**
When multiple gratings with different wavelengths are connected in series on a single optical fiber, a multi-channel, wide-spectral-range demodulator is the sole central unit for achieving independent measurement point differentiation, crosstalk suppression, and synchronized channel acquisition.
### III. Official Technical Specifications and Corresponding Products
For high-precision, high-reliability industrial and research demodulation needs, OFSCN® provides standardized spectral demodulation hardware:
#### [OFSCN® Fiber Bragg Grating Interrogator](https://www.ofscn.net/fbg-products/analyzer.html)
 ![OFSCN® Fiber Bragg Grating Interrogator 8CH](https://forum.ofscn.net/uploads/default/original/1X/8ecc1c112d2015cbc63afa6d42b87517befb2f87.jpeg)
 ![OFSCN® Fiber Bragg Grating Interrogator 32CH](https://forum.ofscn.net/uploads/default/original/1X/248718a63e2aa4cf7db24ad7a4df5ace79c95a05.jpeg)
**Core Specification Metrics:**
- **Working Wavelength Range:** Default 1525 \sim 1565\text{ nm} or 1528 \sim 1568\text{ nm} (larger range customizable);
- **Channel Configuration:** 4-channel, 8-channel, 16-channel, 32-channel options available;
- **Sampling Frequency:** 10\text{ Hz}, 50\text{ Hz}, 100\text{ Hz} options available (software adjustable downwards, down to 1\text{ Hz});
- **Wavelength Resolution:** Default 1\text{ pm}, or high-precision 0.1\text{ pm} (customizable);
- **System Architecture & Interface:** Default B/S architecture software, supports C/S architecture, supports communication protocols like TCP, UDP, Modbus for integration with external control systems.
More related information can be found at [OFSCN® Fiber Bragg Grating Interrogator Products Aggregation Link](https://www.ofscn.net/fbg-topics/analyzer-demodulator.html) .
