Why can boiling water (100°C) damage standard patch cords?
Does the plastic jacket of a standard jumper melt or soften at high temperatures?
From the perspective of polymer physics and materials engineering, the plastic sheath of ordinary fiber optic patch cords softens (i.e., enters the highly elastic state and undergoes severe thermal deformation) rather than completely melting (i.e., entering the viscous flow state) at 100\ ^\circ\text{C} (the boiling point of water).
To understand this physical process more precisely, we need to analyze it scientifically from the following perspectives:
I. Physical State Transition of the Plastic Sheath: Softening vs. Melting
The sheath of conventional OFSCN® Standard Fiber Patch Cords is typically made of thermoplastic materials such as polyvinyl chloride (PVC) or low smoke zero halogen flame retardant polyolefin (LSZH). The molecular structure of these amorphous or semi-crystalline polymers dictates that they do not have sharp, fixed melting points like small molecular crystals such as ice, but rather a broad temperature range of change.
1. Why “Softening”? (Glass Transition)
Conventional PVC typically has a glass transition temperature (T_g) between 75\ ^\circ\text{C} and 85\ ^\circ\text{C}.
When the ambient temperature reaches 100\ ^\circ\text{C}, it significantly exceeds its T_g. At this point, the frozen polymer chain segments in the amorphous regions begin to move vigorously. The material transitions from a hard and brittle “glassy state” to a “highly elastic state” characterized by high flexibility and ease of deformation. Macroscopically, this manifests as extreme softening, with a drastic drop in mechanical strength (tensile and compressive resistance). Under very slight external forces (even just gravity or water flow disturbance), permanent deformation will occur.
2. Why Not “Completely Melted”? (Viscous Flow Transition)
“Melting” physically corresponds to the complete transition of the polymer into a “viscous flow state” where it can flow. Conventional PVC typically requires processing temperatures of 150\ ^\circ\text{C} to 180\ ^\circ\text{C} or higher for melting.
Therefore, in 100\ ^\circ\text{C} boiling water, although the plastic sheath loses its original geometric stability and mechanical protection, its macromolecules have not yet reached a state where they can slide and flow freely. In other words, it becomes a soft plastic material similar to modeling clay, rather than flowing away as a liquid.
II. Why Does 100°C Boiling Water Completely Damage Ordinary Patch Cords?
Ordinary patch cords fail in boiling water due to the failure of multiple layers under high temperature:
  1. Sheath Failure: As mentioned, the PVC or LSZH sheath (typically rated for operating temperatures between -20\ ^\circ\text{C} and 50\ ^\circ\text{C}, or at most 75\ ^\circ\text{C}) softens extremely when heated, losing its micro-bend protection for the internal optical fibers.
  2. Coating Degradation: Ordinary optical fibers are coated with an acrylate coating layer over the bare silica fiber. Standard acrylate coatings typically have a long-term temperature resistance below 85\ ^\circ\text{C}. In 100\ ^\circ\text{C} water, the coating layer undergoes thermal aging, softening, or even localized delamination and thermal decomposition. This leads to uneven stress on the silica fiber, causing significant micro-bend losses, and potentially causing the fiber itself to become brittle and break.
  3. Connector Components and Curing Agent Failure: In conventional fiber optic connectors (with a maximum operating temperature of around 65\ ^\circ\text{C}), the epoxy resin adhesive used to secure the fiber within the ceramic ferrule softens severely at 100\ ^\circ\text{C}. The plastic positioning components of the connector undergo thermal deformation, leading to a sharp increase in fiber insertion loss, or even fiber “retraction” or detachment from the ferrule.
III. Industrial-Grade Solution: High-Temperature Resistant Fiber Optic Patch Cords
To achieve stable optical communication or fiber optic sensing in extreme environments above 100\ ^\circ\text{C} (such as boiling water, steam, or high-temperature oil wells), Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) has redesigned the traditional plastic sheath and coating layers to introduce a series of metal-armored high-temperature resistant patch cords:
  • OFSCN® 120℃ Fiber Optic Patch Cord: Operating temperature range from -40\ ^\circ\text{C} to 120\ ^\circ\text{C}. It eliminates the plastic sheath and instead uses a 0.9\ \text{mm} seamless stainless steel tube for physical armoring. The internal optical fiber features a high-temperature resistant polyacrylate coating, enabling stable operation in boiling water.
  • OFSCN® 200℃ Fiber Optic Patch Cord: Operating temperature range from -200\ ^\circ\text{C} to 200\ ^\circ\text{C}. It utilizes seamless stainless steel tube armoring and a high-strength polyimide-coated optical fiber, offering extremely redundant physical and optical stability in 100\ ^\circ\text{C} environments.
In summary, the sheath of ordinary patch cords severely softens and loses its mechanical strength in boiling water because it surpasses its glass transition temperature. Combined with the failure of the internal coating layer and connector adhesive, this ultimately leads to the complete destruction of the patch cord. For working environments involving boiling water or high-temperature steam, stainless steel armored patch cords with high-temperature resistant coatings must be used.
