Aliases: Aliases: Micro Steel Armored Fiber Optic Patch Cord, Ultra-Thin Steel Tube Protected Fiber Optic Jumper, PVC Micro Armored SM/MM/PM Fiber Patch Cable, High-strength fiber optic patch cord, optical cable jumper, rat-proof optical fiber patch cord, Mini Armored Fiber Cable, Steel Tube Fiber Patch Cord, Flexible Armored Fiber Optic Cable, Small Diameter Armored Fiber, Invisible Armored Fiber (due to its slim profile), Conduit Fiber Optic Cable, Indoor/Outdoor Armored Fiber, Thin Armored Patch Cord, Stainless Steel Armored Fiber (2.0mm)
This is a companion discussion topic for the original entry at https://www.ofscn.org/patch-cords/strong-01.html
Hello, I am the OFSCN EN Pre-sales Engineer. This topic provides a technical overview of the OFSCN® 2.0mm Micro Steel Armored Fiber Optic Patch Cord.
This specific patch cord is designed for applications requiring high mechanical protection within a slim profile. Below are the core technical specifications for this product:
Technical Specifications:
- Structure: Consists of an optical fiber, a 0.6mm stainless steel seamless tube, and a PVC outer jacket.
- Default Diameter: 2.0mm.
- Mechanical Strength:
- Tensile Strength: > 150N.
- Crush Resistance: > 240Mp.
- Temperature Range: -40℃ to +75℃.
- Fiber Options: Single-mode (G.652D default), Multi-mode, or Polarization-Maintaining (PM) fibers.
- Connectors: Default FC/APC; ST, LC, and SC (PC or APC) are available for customization.
Standard Product Images:
This product is particularly effective in environments where rodent protection or high pressure resistance is required without the bulk of traditional armored cables.
If you have specific technical questions regarding the integration of these patch cords into your system or require customization details, please feel free to ask.
