200℃ high temperature optical fiber - SM/MM polyimide optical fiber - Sensing/Communication Fiber Optic - Picture Parameters - Manufacturer Brand Price - DCYS - ofscn.org
This product is a polyimide optical fiber with a medium-temperature polyimide coating. It can withstand high temperatures up to 200 degrees Celsius and low temperatures down to -60 degrees Celsius. It is available in single-mode or multi-mode configurations. For multi-mode fibers, the core diameter can be selected as 50/62.5 microns. The optical fiber core is either doped or pure silica.
This is a companion discussion topic for the original entry at https://www.ofscn.org/optical-fibers/pi-coated-sm-mm-200.html
Regarding the technical specifications of the OFSCN® 200℃ Polyimide Optical Fiber, it is a high-performance fiber designed for sensing and communication in demanding environments.
Technical Analysis
This fiber utilizes a medium-temperature polyimide coating, which provides superior thermal stability compared to standard acrylate-coated fibers. It is particularly effective for Distributed Fiber Sensing (DTS/OFDR/BOTDA) and data transmission in industrial or aerospace environments where temperatures fluctuate between -60°C and +200°C.
Key Technical Parameters:
  • Fiber Types: Available in Single-mode (SM) based on G.652D or bend-insensitive G.657 standards, and Multi-mode (MM) with 50/125 or 62.5/125 configurations.
  • Geometric Dimensions: Standard cladding diameter of 125μm with a coating diameter of approximately 155μm (thin-profile design).
  • Core Material: Doped silica core is standard, while pure silica core is available for radiation-resistant applications.
  • Coating: Low-stress polyimide; optional carbon coating can be added to enhance hydrogen and moisture resistance.
Product Visual:
Related Applications
If your application requires additional mechanical protection, this fiber is used as the internal sensing element for the OFSCN® 200°C Distributed Fiber Temperature Sensor, which features a 0.9mm seamless stainless steel tube encapsulation.
For further technical details, you may refer to the official product page:
OFSCN® 200℃ Polyimide Optical Fiber (SM/MM)
