This product is a series of high-temperature resistant fiber optic connectors (optical fiber connectors) that can withstand up to 200°C, produced by Beijing Dacheng Yongsheng Technology Co., Ltd. (short for DCYS). The types of fiber optic interfaces include FC, ST, SMA. The usable fibers include single-mode fiber, multimode fiber, polarization-maintaining fiber, microstructured fiber, and others.
This is a companion discussion topic for the original entry at https://www.ofscn.org/connectors/high-temperature-200.html
The OFSCN® 200℃ Fiber Optic Connector is a high-performance interconnect solution specifically engineered by Beijing Dacheng Yongsheng Technology Co., Ltd. (DCYS) for extreme thermal environments. Unlike standard connectors that fail due to the softening of internal adhesives and plastic components at elevated temperatures, this series maintains optical stability up to 200°C.
Technical Overview
- Temperature Range: Stable operation up to 200°C.
- Interface Types: Available in FC/PC, FC/APC, ST/PC, ST/APC, and SMA905.
- Fiber Compatibility: Compatible with Single-mode (SM), Multimode (MM), Polarization-maintaining (PM), and specialized microstructured fibers.
- Construction: Utilizes specialized high-temperature resistant ceramics, metals, and proprietary thermal-set adhesives to ensure the ferrule and fiber remain aligned under thermal expansion.
Product Visuals
Application Matching
These connectors are typically paired with specialized fibers to form a complete high-temperature link. Depending on your specific thermal requirements, they are often used alongside:
For environments exceeding 200°C, we also provide the OFSCN® 300℃ Fiber Optic Connector.
Detailed technical parameters and datasheets can be found at: https://www.ofscn.org/connectors/high-temperature-200.html
