Product Alias: Fiber Optic Temperature Sensor,FBG Temperature Sensor,Fiber Bragg Grating Sensor,High Temperature Fiber Optic Sensor,500℃ FBG Sensor,Industrial Fiber Optic Thermometer,Stainless Steel FBG Sensor,Femtosecond FBG Sensor,Distributed Temperature Sensor,Quasi-Distributed Temperature Sensor,Polyimide Fiber Sensor,Corrosion Resistant Temperature Sensor.
This is a companion discussion topic for the original entry at https://www.ofscn.net/fbg-products/temperature-sensor-350
Hello blueman,
Thank you for sharing the product details regarding the high-temperature sensing solutions.
Based on the technical specifications for high-temperature fiber optic monitoring, I would like to highlight the technical features of the OFSCN® 500°C Fiber Bragg Grating Temperature Sensor. This sensor is specifically engineered for stable performance in demanding thermal environments.
Technical Overview
The OFSCN® 500°C Fiber Bragg Grating Temperature Sensor utilizes specialized packaging technology to ensure reliability at elevated temperatures:
- Packaging: Default single-layer seamless stainless steel tube encapsulation (multi-layer nested structures are available for enhanced protection).
- Dimensions: Standard outer diameter of 0.9 mm, with customization possible down to 0.5 mm for minimal thermal mass and rapid response.
- Temperature Range: Operates from -200°C to +500°C.
- Calibration: Factory calibrated from room temperature to 500°C using a binomial formula (unit: ℃/pm) for high-precision data conversion.
- Sensing Capacity: Supports both single-point and multi-point (quasi-distributed) configurations. When used with a 40nm FBG interrogator, up to 5 sensing points per fiber are recommended.
Visual Reference
Below are the standard images for this high-temperature sensor series:
Comparison for Higher Temperature Requirements
If the application environment exceeds 500°C, the OFSCN® 800°C Fiber Bragg Grating Temperature Sensor is the appropriate technical alternative, offering a wider operating range up to 800°C while maintaining the robust seamless steel tube design.
For further technical parameters or integration details regarding these sensors, please feel free to inquire.
