If the fiber optic cable breaks, do I have to buy a fusion splicer that costs tens of thousands of yuan? Is there a simpler way?
After optical fiber breaks, you do not necessarily need to purchase expensive fusion splicers. In fiber optics and field engineering maintenance, there are various technical solutions and engineering alternatives for repairing fiber breaks, depending on the actual application environment, sensing signal requirements, and loss tolerance.
I. Comparison of Common Optical Fiber Splicing Methods
Optical fiber splicing essentially involves aligning the cores of two optical fibers (the core diameter of single-mode optical fibers is typically only about 9\ \mu\text{m}) with micron-level precision and maintaining optical continuity. The main methods are divided into two categories:
1. Mechanical Splicing (Cold Splicing, Low-Cost Solution)
- Principle: Utilizes a precision V-groove structure to tightly butt the end faces of two bare fibers. The internal space is pre-filled with refractive index matching gel (or silicone oil) that matches the refractive index of the silica core, eliminating Fresnel reflection caused by air gaps.
- Required Tools:
- Fiber optic stripper (Miller stripper)
- Fiber optic cleaver (high-precision cutting with end-face angle < 1^\circ)
- High-purity anhydrous alcohol and lint-free wipes
- Mechanical splice (individual cost is extremely low)
- Advantages: No arc discharge fusion splicer required, very low tool kit cost, quick and portable operation.
- Technical Limitations:
- Relatively high insertion loss (typical values around 0.1\ \text{dB} \sim 0.3\ \text{dB}, while hot fusion is generally < 0.02\ \text{dB}).
- Weather resistance is limited: The internal matching gel may fail or volatilize over long-term use, under UV exposure, at extreme high/low temperatures (beyond -40^\circ\text{C} \sim 75^\circ\text{C}), or in environments with severe vibration.
2. Fusion Splicing
- Principle: Uses high-voltage electric arc discharge to soften and melt silica glass at high temperatures (approximately 1500^\circ\text{C} \sim 2000^\circ\text{C}), forming a continuous connection of the glass molecular network.
- Current Status: Portable core-alignment/cladding-alignment fusion splicers for common single-mode fibers (like G.652D, G.657) have become widely affordable in the market. It is not necessary to purchase high-end equipment costing tens of thousands of dollars (high-end equipment is typically for polarization-maintaining fibers, large-core fibers, or specialized R&D).
- Advantages: High physical strength, extremely low optical loss, and excellent long-term environmental resistance.
II. Alternative Solutions in Engineering
- Temporary/Permanent Borrowing on Site: If only individual measurement points or links are broken, contact local low-voltage engineering personnel, telecommunication network maintenance staff, or university/research laboratories with fusion splicing equipment to borrow or commission splicing. The cost of a single service is far lower than the investment in equipment.
- Fiber Optic Connector + Ferrule Adapter: Use field-cold-spliced rapid connectors (e.g., FC/APC or SC/APC field connector plugs) to crimp the broken ends separately into connectors, then connect them via a standard fiber optic adapter.
- Patch Cord Replacement: If the break occurs in an external armored patch cord segment, replacing the standard patch cord is often more reliable than repairing the bare fiber on-site.
III. Precautions for Fiber Bragg Grating (FBG) Sensing Links
In Fiber Bragg Grating (FBG) wavelength demodulation systems, since the demodulator detects the characteristic center wavelength (\lambda_B) reflected by the grating, the wavelength value itself has strong tolerance to optical attenuation (as long as the return signal strength is above the lower limit of the demodulator’s dynamic range), therefore:
- Conventional Laboratory/Indoor Environments: Mechanical connectors or cold splices are perfectly adequate for FBG signal transmission.
- Harsh/High-Temperature Working Environments: If the optical fiber is in an area of high temperature (e.g., > 120^\circ\text{C}), strong vibration, high vacuum, or chemical corrosion, the plastic components and matching gel inside mechanical cold splices will not function. In such cases, the break point must be fusion spliced using specialized high-temperature resistant equipment and protected with a metal sleeve.
(Note: Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) core business covers Fiber Bragg Grating sensors, high-temperature resistant optical fibers, and metal-armored fiber optic patch cords. Fusion splicers, mechanical connectors, strippers, and cleavers are general construction tools and not part of OFSCN®'s core product line.)
