If a reservoir dam has a water seepage issue, how can fiber optics detect it using temperature?
In the safety monitoring of reservoir dam engineering, the basic principle of fiber optic detection of leakage is not to directly detect “water” itself, but to use temperature as a natural tracer, and to identify and spatially locate leakage channels by utilizing the local thermal field anomalies caused by water flow.
The core physical mechanisms and engineering implementation methods are mainly divided into the following two modes:
I. Core Physical Mechanism
1. Passive Temperature Tracing Method (Natural Temperature Difference and Convective Heat Transfer)
- Natural Gradient of Ground Temperature Field and Water Temperature: The geothermal field inside the dam and the surrounding rock and soil layers typically has a natural geothermal field that changes slowly with depth and is relatively constant; the reservoir water is directly affected by seasons, ambient temperature, and solar radiation, with significant stratification of water temperature at different depths. Therefore, there is usually a fixed natural temperature difference ( \Delta T ) between the reservoir water and the media inside the dam.
- Perturbation of Convective Heat Transfer Equilibrium: In the absence of leakage, heat transfer within the dam primarily relies on the slow thermal conduction of solid media, resulting in a smooth and stable temperature gradient. Once the anti-seepage body of the dam cracks or experiences piping leakage, reservoir water flows rapidly along the leakage fissures. The strong convective heat transfer of the water flow rapidly reshapes the temperature distribution around the seepage path, forming significant local
