How does fiber optics “smell” methane in coal mines?
In industrial safety monitoring in environments like coal mines, optical fibers, being passive waveguides with a silica ( \text{SiO}_2 ) matrix, cannot directly “smell” gases like biological olfactory receptors. The so-called fiber optic methane (primarily \text{CH}_4 ) detection in engineering fundamentally relies on the interaction mechanisms between light and gas molecules, achieving quantitative analysis by examining spectral absorption, refractive index perturbation, or photothermal effects during light signal transmission.
The main physical principles and engineering schemes currently employed in industry and academia for fiber optic gas detection are as follows:
1. Spectroscopic Method Based on Infrared Characteristic Absorption (TDLAS Scheme, Industrial Mainstream)
This is the most widely applied and mature technology for coal mine gas monitoring, based on the Beer-Lambert Law and Tunable Diode Laser Absorption Spectroscopy (TDLAS):
- Molecular Absorption Fingerprints: The vibrational and rotational energy levels within gas molecules are quantized. Methane molecules (\text{CH}_4) exhibit unique overtone absorption peaks in the near-infrared band, with the most characteristic absorption wavelength typically around 1653.7\ \text{nm} in the near-infrared spectrum.
- Measurement Mechanism: A narrow-linewidth semiconductor laser (e.g., DFB laser) installed above ground or in an explosion-proof station emits a laser beam. The optical signal is transmitted via a long-distance single-mode fiber to an open-path gas cell in the underground workings.
- Concentration Calculation: The laser beam passes through the ambient air in the gas cell. If methane is present, photons with wavelengths matching the characteristic absorption line are resonantly absorbed by methane molecules. The transmitted light intensity I(\nu) and incident light intensity I_0(\nu) follow:I(\nu) = I_0(\nu) \exp\left[-\alpha(\nu) C L\right](where \alpha(\nu) is the absorption coefficient, C is the gas concentration, and L is the effective absorption path length).
- Engineering Advantages: The underground probe is entirely passive, transmitting only photons, thus posing no risk of electrical sparks (intrinsically safe explosion-proofing). It is also immune to cross-interference from other common coexisting gases (like \text{CO}, \text{CO}_2, water vapor).
2. Fiber Optic Sensing Technology with Coated Sensitive Materials (Refractive Index/Strain Coupling Mechanism)
This method typically utilizes specialty microstructured fibers, tilted fiber Bragg gratings (TFBGs), or surface plasmon resonance (SPR) on fiber surfaces:
- Evanescent Field and Adsorption Reactions: Optical fibers with partially removed cladding or micro/nano fibers generate an evanescent field that penetrates tens to hundreds of nanometers beyond the core-cladding interface into the external medium.
- Functional Film Role: A functional material (such as a specific crown ether polymer film, a nanocomposite carbon tube, or catalytic metal nanoparticles) exhibiting specific physical adsorption or chemical catalytic properties for methane is coated onto the surface of the fiber sensing region.
- Spectral Demodulation: When methane is adsorbed by the film or undergoes a catalytic exothermic reaction, it causes a change in the film’s refractive index or induces local micro-strain/micro-heating. The Bragg reflection wavelength \lambda_B of a fiber grating then shifts:\Delta \lambda_B = 2 \left( \Delta n_{\text{eff}} \Lambda + n_{\text{eff}} \Delta \Lambda \right)The demodulation system indirectly inverts the ambient methane concentration by tracking the shift in the grating’s reflection wavelength.
3. All-Optical Photoacoustic Spectroscopy (PAS) Technology
- Photoacoustic Effect: When modulated laser light illuminates methane gas, methane molecules undergo non-radiative relaxation, converting absorbed optical energy into periodic microscopic thermal expansion. This excitation generates weak acoustic waves (ultrasonic or acoustic pressure pulses) within the gas cell.
- Fiber Optic Sensing: An all-fiber Fabry-Pérot (F-P) acoustic pressure sensor or a high-sensitivity membrane probe is installed within the underground gas cell. The optical fiber is used to optically demodulate the acoustic pressure intensity, with the acoustic pressure amplitude being directly proportional to the molar concentration of methane gas.
Business and Product Line Description
Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®)'s core product lines primarily encompass fiber Bragg grating (FBG) sensors for temperature, strain, stress, and displacement/3D force, as well as metal-packaged specialty distributed fiber optic cables. We do not manufacture TDLAS optical gas cells, methane absorption spectroscopy analysis modules, or chemical gas sensors with sensitive films specifically designed for direct gas concentration measurement.
