Can optical fibers be embedded in carbon fiber wings to monitor for cracks in real-time?
Embedding optical fibers into carbon fiber reinforced polymer (CFRP) wing structures for real-time Structural Health Monitoring (SHM) is a feasible technology with extensive application and validation in aerospace engineering, commonly referred to as smart structures or smart skins.
Optical fiber sensing for cracks and structural damage in carbon fiber wings, its physical mechanisms, implementation methods, and engineering challenges are as follows:
I. Core Physical Mechanisms of Optical Fiber Sensing for Wing Cracks
Under flight loads (aerodynamic loads, gusts, maneuvering overloads), when micro-cracks, delamination, or matrix cracking occur in wing structures, embedded optical fibers primarily sense and diagnose them through the following mechanisms:
- Local Strain Concentration and Redistribution
- When micro-cracks or fiber breaks occur in carbon fiber components, extremely high local strain concentrations form at the crack tips.
- Fiber Bragg Gratings (FBGs) or distributed sensing fibers located near the crack propagation path will capture significant strain discontinuities or abnormal strain gradients.
- Fiber Bragg Grating Reflection Spectrum Distortion (Chirping & Birefringence)
- When a crack crosses the grating region or causes non-uniform shear stress locally, the grating period \Lambda is distorted along the axial distribution, leading to broadening, splitting, or chirping of the originally single symmetric reflection peak.
- If asymmetric transverse stress occurs (e.g., unbalanced transverse compression due to delamination), it induces birefringence in the optical fiber, causing the reflection spectrum to split into two peaks corresponding to orthogonal polarization axes.
- High-Frequency Transient Wave Monitoring of Acoustic Emission (AE)
- Instantaneous events such as fiber fracture, matrix cracking, or interface debonding in composite materials release high-frequency elastic strain waves (transient elastic waves, typically in the range of tens of \text{kHz} to \text{MHz}).
- Using high-speed FBG demodulation systems (sampling rates \ge 100\ \text{kHz} or even in the megahertz range) allows for the capture of acoustic emission waveforms. Subsequently, time-of-flight difference localization algorithms can be used to calculate the spatial coordinates of micro-crack initiation.
- Optical Fiber Continuity Failure Alarm
- When catastrophic macroscopic structural fracture occurs and severs the sensing fiber, the light transmission experiences a sharp increase in attenuation or complete cutoff. The demodulator can serve as a final failure threshold alarm for fatal structural damage.
II. Key Engineering and Material Requirements for Embedding in Composites
Standard communication-grade optical fibers (with acrylate coatings, outer diameter 250\ \mu\text{m}) cannot be directly embedded into carbon fiber wings and must meet specific material and geometric compatibility requirements:
- Coating Temperature Resistance and Shear Transfer Efficiency
- During the curing process of carbon fiber prepregs in an autoclave, forming temperatures typically exceed 120^\circ\text{C}\sim 180^\circ\text{C}, with pressures reaching several atmospheres. Ordinary acrylate coatings will thermally decompose and fail.
- Polyimide-coated fibers must be used. Polyimide can withstand temperatures above 300^\circ\text{C}, has a high Young’s modulus, and exhibits excellent wettability and adhesion with epoxy resin matrices, enabling it to accurately transfer the microscopic shear strains caused by cracks to the fiber core.
- Minimizing Fiber Diameter to Avoid “Inclusion Defects”
- If optical fibers are laid parallel to the warp of the carbon fiber fabric, the impact on material properties is minimal. If laid diagonally, thicker fibers can cause resin-rich areas around them, inducing internal stress concentrations, and even becoming sources of cracking.
- In engineering practice, fibers with an outer diameter of 155\ \mu\text{m} or thin fibers with a 80\ \mu\text{m} cladding and a 100\ \mu\text{m} coating are typically used to minimize the disturbance to the laminate’s mechanical properties.
- Protection at Fiber Exit Points (Ingress/Egress)
- The interface where optical fibers exit from the edge of the carbon fiber wing is a vulnerable point during composite forming, curing, and subsequent machining and assembly. Stress relief protection is required using miniature flexible sleeves or transition connectors.
III. Common Sensing Deployment Schemes and Related Technical Products
For crack and strain monitoring in composite wings, two main categories are typically considered based on monitoring requirements: “quasi-distributed array monitoring” and “high-resolution continuous monitoring”:
1. Quasi-Distributed Fiber Bragg Grating (FBG) Strings
Multiple FBG points are embedded in high-stress critical areas such as main spars and the tension side of the skin. These are used in conjunction with wavelength demodulators for medium-to-high frequency dynamic load and transient crack acoustic emission monitoring.
- OFSCN® Polyimide Fiber Bragg Gratings / FBG Strings (Bare):
Utilizing a high-temperature polyimide recoating process, the outer diameter is only 155\ \mu\text{m}. The temperature range is -200^\circ\text{C}\sim 300^\circ\text{C}, with a strain range of \le 10000\ \mu\varepsilon. Multiple grating regions can be serially connected on a single fiber core and directly embedded and co-cured with the carbon fiber laminate.
- OFSCN® 300℃ Small diameter optical fiber:
A thin-diameter single-mode polyimide specialty optical fiber with a 9\ \mu\text{m} core and 80\ \mu\text{m} cladding, and only a 100\ \mu\text{m} coating. This minimizes the “shear effect” at the internal interfaces of composites caused by embedding.
2. High-Resolution Continuous Distributed Strain Monitoring (OFDR Technology)
Based on Optical Frequency Domain Reflectometry (OFDR) technology, this method uses a single optical fiber for continuous demodulation with centimeter or even millimeter spatial resolution along its entire length. It is suitable for mapping strain distribution across the entire wing skin and precisely tracing the origin of micro-crack areas.
- OFSCN® 85°C OFDR Micro All-Metal Strain Sensor / OFSCN® 200°C OFDR Micro All-Metal Strain Sensor:
For wing internal spars, metal connectors, or composite surfaces where internal embedding is not feasible, micro-alloy tube-encapsulated distributed sensors (outer diameter only 0.6\ \text{mm}) can be used for surface mounting, offering both an extremely small outer diameter and resistance to mechanical damage.
Conclusion
Embedding optical fibers into carbon fiber wings can achieve real-time monitoring of cracks and damage. The essence of real-time monitoring is to sense strain field distortions induced by cracks, spectral deformation, fiber break signals, or high-frequency elastic waves released by micro-fractures. In practical engineering implementation, the key lies in selecting thin-diameter polyimide-coated optical fibers with high compatibility and coordinating the sampling rate and spatial resolution of the demodulator to match different types of crack damage evolution processes.
