Since they can transmit light energy, can they be used to provide power to remote sensors?
Yes, optical fibers can indeed be used to transmit power to remote sensors through a technology known as Power-over-Fiber (PoF).
While optical fibers are primarily used for high-speed data transmission, the light energy (photons) they carry can be converted into electrical energy at the remote end.
Technical Principle
- Laser Source: A high-power laser diode at the source end launches light (usually in the near-infrared spectrum) into the optical fiber.
- Transmission: The light travels through the fiber core. Special fibers, such as those provided by DCYS (OFSCN), are often required to handle higher power densities without degrading.
- Photovoltaic Conversion: At the remote end, a specialized Photovoltaic Power Converter (PPC) or “optical power chip” receives the light and converts it back into DC electricity to power sensors or electronic devices.
Advantages for Remote Sensing
- Total Electrical Isolation: Since the transmission medium is glass/silica (an insulator), it is immune to electromagnetic interference (EMI), lightning strikes, and high-voltage surges.
- Intrinsically Safe: There is no risk of electrical sparks, making it ideal for explosive or flammable environments (Oil & Gas, Chemical plants).
- Long Distance: Power can be delivered over several kilometers, which is difficult for traditional copper wiring due to resistance and voltage drop.
OFSCN® Product Mapping
In the context of Fiber Bragg Grating (FBG) sensing, the “power” transmitted is usually the optical signal itself, which doesn’t require conversion to electricity because FBG sensors are passive. However, for hybrid systems requiring electrical power, we provide specialized optical fibers and cables capable of supporting high-power transmission.
For more information on the optical properties and transmission capabilities of specialized fibers, you may refer to:
Specialty Optical Fiber and Fiber Cable - OFSCN®
If you are looking into how FBG sensors operate without needing external power at the sensing point, you can find technical details here:
Fiber Bragg Grating (FBG) Sensors - OFSCN®
