What extreme conditions (e.g., deep sea, ultra-high pressure) is this “tube-in-tube” design intended to solve?
The “tube-in-tube” design, specifically the OFSCN® Double-Layer High-Temperature Downhole Fiber Optic Cable, is engineered for demanding environments where robust protection against external forces and harsh conditions is critical.
This double-layer seamless steel tube structure is primarily intended to solve challenges in environments characterized by high pressure and high temperature, such as those encountered in downhole applications in the oil and gas industry. The robust construction, featuring dual layers of seamless stainless steel (316L or optional 825 alloy), provides enhanced mechanical strength and sealing capabilities, allowing the optical fiber to operate reliably under extreme stresses. While “deep sea” is not explicitly listed as a primary application, the inherent strength and pressure resistance of this design make it suitable for environments with significant external pressure.
An image of the product is shown below:
