Elastic Modulus (E) of Packaging Materials
Why does choosing materials with a high elastic modulus help improve strain transfer efficiency?
Choosing materials with a high elastic modulus for packaging helps improve strain transfer efficiency because the elastic modulus (E) is a measure of a material’s stiffness or its resistance to elastic deformation under stress.
Here’s a detailed explanation:
  1. Stiffness and Deformation: A material with a high elastic modulus is stiff, meaning it requires a greater force to produce a given amount of deformation (strain).
  2. Efficient Strain Transmission: In the context of a fiber optic strain sensor, the packaging material acts as an intermediary between the host structure being monitored and the Fiber Bragg Grating (FBG) element itself. For accurate measurement, the strain occurring in the host structure must be transferred as effectively as possible to the FBG.
  3. Minimizing Loss: If the packaging material has a low elastic modulus (is less stiff), it will deform more readily than a stiffer material. This can lead to the packaging material absorbing or dissipating some of the strain from the host structure, rather than fully transmitting it to the FBG. As a result, the FBG would measure a lower strain than what is actually present in the host structure, leading to inaccurate readings.
  4. Accurate Representation: By using a packaging material with a high elastic modulus, the material will deform proportionally and with minimal loss when the host structure strains. This ensures that the FBG experiences a strain level that closely matches the strain in the host structure, providing a more accurate and efficient measurement.
OFSCN designs its packaged fiber Bragg grating strain sensors using robust materials to ensure high strain transfer efficiency and reliable performance across various applications and environmental conditions.
You can find more technical details on our strain sensor products here:
