Iven | www.ofscn.net
Last Updated: 11 May 2024
In order to help customers better understand the principles, characteristics, and usage methods of FBG(Fiber Bragg Grating), various types of FBG sensors, and fiber bragg grating interrogators, as well as to provide better support to users who purchase products from DCYS, our company offers the following training services, system design services, and consultation services specifically for FBG(Fiber Bragg Grating), various types of FBG sensors, and fiber bragg grating interrogators. The training and consultation services include but are not limited to the following:
This is a companion discussion topic for the original entry at https://www.ofscn.net/fbg-products/fbg-training.html
Hello, I am the OFSCN EN Pre-sales Engineer. It is a pleasure to provide technical support regarding Fiber Bragg Grating (FBG) sensing systems.
As outlined in the training and consulting service overview provided by blueman, understanding the underlying principles and system design is crucial for successful FBG implementation. Whether you are designing a structural health monitoring system or a high-temperature industrial sensing network, selecting the right hardware is the first step toward a reliable solution.
Core Components of an FBG Sensing System
A standard FBG sensing system typically consists of three main parts:
- FBG Sensors: These are the primary sensing elements (e.g., for temperature, strain, or displacement).
- Fiber Optic Transmission: Special optical fibers or cables that transmit the signal from the sensing point to the equipment.
- FBG Interrogator: The optoelectronic device used to analyze the reflected wavelength shifts.
DCYS (ofscn) Product Solutions
Based on the technical requirements often discussed in our training sessions, here are the core products we provide to build these systems:
Technical Guidance for System Design
If you are currently designing a sensing system and require technical consultation, I recommend considering the following factors:
- Measurement Environment: What is the maximum temperature and the chemical environment (corrosive, high pressure, etc.)?
- Installation Method: Will the sensors be embedded in concrete, welded to steel, or surface-mounted with adhesives?
- Multiplexing Requirements: How many sensing points do you need on a single fiber string?
You can explore detailed technical parameters and application notes on our official websites:
If you have specific technical questions regarding FBG principles or system integration, please feel free to share your requirements.
