Fiber Bragg Grating Reinforcement Gauge - FBG Reinforcement Strain Stress Tension Meter - Image Parameter Customization - Factory Brand Price - DCYS - ofscn.net
Product Alias: Fiber Bragg Grating Rebar Strain Gauge, FBG Smart Rebar, Rebar Strain Gauge, Rebar Deformation Sensor, Rebar Tensile Force Gauge, Rebar Monitor.
This is a companion discussion topic for the original entry at https://www.ofscn.net/fbg-products/rebar-meter
Welcome to the International Zone. As the OFSCN EN Pre-sales Engineer, I am here to provide technical support regarding Fiber Bragg Grating (FBG) sensing technology.
The topic you’ve shared pertains to the OFSCN® Fiber Bragg Grating Rebar Strain Gauge (also known as FBG Smart Rebar). This specialized sensor is a parameter extraction application of the OFSCN® Fiber Bragg Grating strain sensor.
Technical Overview
The OFSCN® Fiber Bragg Grating Rebar Strain Gauge is designed to monitor the internal state of reinforced concrete structures. It can accurately measure:
  1. Deformation (Strain): Monitoring the micro-strain of the rebar under load.
  2. Length Change (Displacement): Assessing the physical shifting or elongation.
  3. Stress/Tension: Calculated based on the elastic modulus of the specific rebar used.
Product Configuration & Core Advantages
Depending on the specific engineering requirements, this gauge typically utilizes two types of internal sensing structures:
Key Technical Benefits:
  • EMI Immunity: Unlike traditional electronic strain gauges, FBG sensors are unaffected by electromagnetic interference, which is critical in large-scale infrastructure projects.
  • Durability: The all-metal alloy tube packaging eliminates issues related to epoxy creep, ensuring long-term reliability within concrete.
  • Multiplexing: Multiple sensors can be integrated into a single optical fiber string to monitor different points along a reinforcement cage.
Standard Product Visualization
Below are the standard structural representations for the underlying sensing technology:
For detailed technical specifications or to discuss how this sensor integrates with your specific rebar diameter and grade, please feel free to ask technical questions here.
You may also review the full documentation at the official product page:
