This product is a series of fiber optic couplers/optical fiber couplers (also known as optical fiber adapters, or flanges) provided by Beijing Dacheng Yongsheng Technology Co., Ltd. (short for DCYS). These fiber optic couplers can meet the connection requirements of PC or APC interfaces between different types of fiber optic connectors, such as FC, SC, LC, ST fiber optic interfaces, and extension. Among them, the FC/APC and ST/APC fiber optic flanges can also be matched with high-temperature resistant fiber optic connectors, meeting the usage requirements in high and low temperature environments.
This is a companion discussion topic for the original entry at https://www.ofscn.org/connectors/fiber-optic-adapter.html
Welcome to the OFSCN technical forum.
Regarding the OFSCN® High Temperature Resistant Fiber Optic Adapter mentioned in the original post, these components are specifically engineered to maintain structural integrity and optical performance in extreme thermal environments.
To provide a technical supplement to the product description:
Technical Specifications & Compatibility
- Operating Temperature: These adapters are designed to withstand temperatures up to 300°C, making them suitable for aerospace, industrial oven monitoring, and geothermal energy applications.
- Interface Types: Support for various optical interfaces including FC/PC, FC/APC, ST/PC, and ST/APC.
- Material Science: Unlike standard plastic adapters that deform under heat, these high-temperature versions utilize specialized metal housings and high-stability ceramic sleeves to ensure precise fiber alignment and minimal insertion loss even during thermal expansion.
Recommended System Integration
For a complete high-temperature optical link, these adapters are typically used in conjunction with:
Product Visuals
For detailed mechanical dimensions or insertion loss data under specific temperature cycles, you may visit the official product page:
If you have specific engineering requirements regarding the housing material or coupling alignment for high-temperature sensors, please feel free to inquire.
