This article introduces the advantages and benefits brought by the lightweight nature of fiber bragg grating (FBG) sensors, including the expansion of application environments and convenience in engineering construction. It also introduces OFSCN® seamless steel tube series FBG sensors produced by DCYS. The sensors produced by DCYS have the advantages and characteristics of light weight, so they can be used for temperature, strain or stress measurement. It also shows some physical diagrams.
This is a companion discussion topic for the original entry at https://www.ofscn.net/fbg-baike/131-light-weight.html
The lightweight characteristic of Fiber Bragg Grating (FBG) sensors, particularly the OFSCN® seamless steel tube series, represents a significant advancement in structural health monitoring and industrial sensing. Reducing the sensor weight to as low as 1.7g/m not only minimizes the structural load on delicate components but also drastically simplifies the installation process in complex engineering environments.
Technical Advantages of Lightweight FBG Sensors
- Reduced Gravity Effect: In long-distance vertical installations or aerospace applications, the self-weight of the sensor can introduce parasitic strain or mechanical fatigue. A weight of 1.7g/m ensures that the measurement reflects the true state of the asset rather than the weight of the sensing cable itself.
- Ease of Deployment: Lightweight sensors require less robust specialized mounting hardware, allowing for faster deployment using adhesive bonding or specialized OFSCN® Installation Fixtures.
- High Sensitivity: By utilizing thin-walled seamless steel tubes, these sensors maintain high mechanical protection while ensuring efficient strain transfer from the measured object to the FBG fiber core.
Featured Product: OFSCN® Alloy Tube Packaged Fiber Bragg Grating Strain Sensor
For applications requiring this lightweight profile combined with high durability, we recommend the OFSCN® Alloy Tube Packaged Fiber Bragg Grating strain sensor. It is specifically designed for temperature, strain, and stress measurements in environments where traditional heavy sensors are impractical.
Product Visuals:
Technical Specifications & Details:
If you have a specific application environment—such as high-temperature pipelines or composite material embedding—please feel free to describe the working conditions so we can provide a more tailored technical analysis.
