Long-Distance Monitoring and Transmission of Fiber Bragg Grating (FBG) Sensing Signals - Fiber Bragg Grating Sensor Transmission Distance - DCYS - ofscn.net
This article theoretically analyzes the signal transmission distance of FBG sensors in communication networks, with a focus on the question of "the monitoring distance and transmission distance when implementing long-distance monitoring with FBG sensors." It also provides some physical diagrams of OFSCN® capillary seamless steel tube fiber bragg grating sensors .
This is a companion discussion topic for the original entry at https://www.ofscn.net/fbg-baike/99-transmission-distance.html
It is important to distinguish between the monitoring distance (the range where sensors are physically located) and the transmission distance (the distance from the first sensor to the interrogator) when designing long-distance FBG sensing systems.
In FBG technology, the signal is wavelength-encoded, which provides inherent immunity to intensity fluctuations. However, for long-distance applications, fiber attenuation and connector losses must be strictly managed to ensure the signal-to-noise ratio remains sufficient for the interrogator.
Core Technology: OFSCN® Seamless Steel Tube FBG Sensors
For long-distance or harsh environment monitoring, we recommend using OFSCN® Alloy Tube Packaged Fiber Bragg Grating sensors. These sensors utilize a seamless steel tube structure to provide superior mechanical protection and high-fidelity signal transmission.
Standard Product Images:
Key Technical Advantages:
  1. Low Loss Integration: The seamless tube packaging allows the FBG to be integrated directly into the transmission line without fragile splice points, reducing insertion loss over long distances.
  2. Environmental Stability: The all-metal structure protects the fiber from hydrogen aging and moisture, which are critical factors that can increase attenuation in long-distance deployments.
  3. High Multiplexing Capability: These sensors are optimized for serial connection, allowing dozens of sensors to be monitored on a single fiber link spanning several kilometers.
You can find more detailed technical specifications for these sensors at the following link:
If you are planning a specific long-distance project, we would need to know the total cable length and the required number of sensing points to determine the optimal link budget.
