How much longer is its period than a regular grating? What special things can be measured?
Long-Period Fiber Gratings (LPGs), as distinct from the commonly encountered Fiber Bragg Gratings (FBGs, or short-period fiber gratings), exhibit significant differences in their physical mechanisms, structural dimensions, and application domains.
The following provides an academic explanation from two perspectives: periodic scale comparison and specialized measurement applications.
I. Periodic Scale Comparison: How much longer is an LPG than a regular grating?
The “period” of a fiber grating refers to the physical spatial pitch (\Lambda) of its refractive index modulation’s periodic variation.
Scale Comparison:
- Regular Short-Period Fiber Grating (FBG): Its period (\Lambda_{FBG}) is typically on the order of hundreds of nanometers (nm). For instance, in the commonly used communication and sensing wavelength band of 1550\text{ nm}, the grating period of an FBG is usually around 500\text{ nm} \sim 540\text{ nm}.
- Long-Period Fiber Grating (LPG): Its period (\Lambda_{LPG}) is typically between tens of micrometers and hundreds of micrometers (\mu\text{m}), with a typical range of 100\ \mu\text{m} \sim 1000\ \mu\text{m}.
- Order of Magnitude Difference: The period of an LPG is approximately 3 orders of magnitude longer (i.e., about 1000 times longer) than that of a regular FBG.
Physical Mechanism Differences:
- FBG (Reflective): It involves coupling between the co-propagating core fundamental mode and the contra-propagating core fundamental mode. The Bragg condition it satisfies is:
\lambda_B = 2 n_{co} \Lambda_{FBG}(where n_{co} is the effective refractive index of the core), which manifests as a narrow-band reflective filter.
- LPG (Transmissive): It involves coupling between the co-propagating core fundamental mode and multiple co-propagating coaxial cladding modes. The resonance condition it satisfies is:
\lambda_i = (n_{co} - n_{cl}^{i}) \Lambda_{LPG}(where n_{cl}^{i} is the effective refractive index of the i-th order co-propagating cladding mode). Because cladding modes rapidly attenuate and dissipate at the interface between the cladding and the coating, LPGs exhibit a series of specific absorption loss peaks in their transmission spectrum.
II. What specialized phenomena can LPGs measure?
Due to their unique physical coupling mechanism, LPGs are capable of measuring specialized environmental parameters that ordinary bare FBGs cannot directly measure:
External Medium Refractive Index (RI):
This is the most representative specialized measurement capability of LPGs. Since LPGs couple energy into cladding modes, and the electromagnetic field of these cladding modes (evanescent waves) extends directly into the external medium outside the fiber, any slight change in the external medium’s refractive index causes a significant shift in the transmission resonance peaks due to the substantial change in the effective refractive index n_{cl}^{i} of the cladding modes.- Application Scenarios: Monitoring chemical solution concentrations, detecting liquid salinity/sugar content, and real-time monitoring of biochemical reactions (e.g., antigen-antibody binding). Ordinary bare FBGs, with their light fields entirely confined within the core, show virtually no response to changes in the external refractive index as long as the fiber cladding is intact.
Ultra-high Sensitivity to Bending and Torsion:
LPGs are extremely sensitive to the asymmetry induced in the cladding by minute deformations of the fiber itself, particularly bending and torsion. Bending can cause mode reconstruction and spectral line splitting in the cladding modes, making them ideal for high-precision measurements of deflection, torsion, and deformation direction in structural health monitoring. -
Decoupling of Cross-Sensitivity between Temperature and Strain:
The transmission spectrum of an LPG contains multiple distinct cladding resonance peaks. Different cladding modes have varying sensitivity coefficients to temperature and strain. By solving a system of multivariate equations, LPGs can simultaneously decouple and measure temperature and strain at a single point on a single fiber, overcoming the challenging temperature-strain cross-sensitivity issue inherent in traditional FBG sensors.
III. Official Technical Statement
It should be specifically noted that Long-Period Fiber Gratings (LPGs) are currently not part of Beijing Dacheng Yongsheng Technology Co., Ltd.'s (OFSCN®) core product line.
Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) primarily focuses its core products and technical solutions on high-precision, high-temperature resistant, and high-strength short-period Fiber Bragg Grating (FBG) series products, including polyimide-coated FBGs, femtosecond laser-inscribed bare FBGs, and seamless steel tube-encapsulated FBG temperature and strain sensors, among others.
