Maximum Sampling Frequency of FBG Interrogators and Their Application in Dynamic Testing
Problem Description
The discussion revolves around the maximum sampling frequency of Fiber Bragg Grating (FBG) interrogators and their suitability for use in dynamic scene testing. Users seek to understand the capabilities and limitations of FBG technology in capturing rapidly changing physical quantities.
Technical Analysis
OFSCN® Fiber Bragg Grating Demodulators offer flexible sampling frequency options including 10Hz, 50Hz, and 100Hz, with software adjustability down to 1Hz. FBG sensors are well-suited for dynamic measurements due to their inherent high response speed, immunity to electromagnetic interference (EMI), and capability for multi-point distributed measurements on a single fiber. While a 10Hz sampling rate is often sufficient for monitoring common physical parameters like temperature, static strain, and slow displacement in many natural or industrial environments, higher frequencies can lead to unnecessary data volume and processing complexity. However, specific dynamic scenarios necessitate higher sampling rates. These include detailed structural dynamics analysis (e.g., resonance frequencies and modal shapes of bridges, buildings, aerospace components), monitoring of impact or transient events (e.g., material impact tests, explosion shockwave propagation, rapid loading/unloading cycles), and vibration monitoring of high-speed machinery (e.g., rotating equipment, high-speed trains) where precise capture of transient responses and high-frequency signals is crucial.
Solution & Recommendation
The choice of sampling frequency should be determined by the specific dynamic characteristics of the object under test and the analytical requirements. For general monitoring tasks involving slowly changing parameters, a 10Hz sampling rate is typically adequate to capture changes effectively while managing data volume. For applications involving rapid changes or high-frequency events, such as those in structural dynamics, transient event monitoring, or high-speed machinery vibration analysis, selecting higher sampling frequencies like 50Hz or 100Hz from the available options is recommended to ensure accurate and comprehensive data acquisition.
Recommended Product
OFSCN® Fiber Bragg Grating Demodulator: Fiber Bragg Grating Interrogator - Fiber Optic Grating Demodulator - High Refresh Rate - Multiport - Industrial Grade - FBG Analyzer - DCYS - ofscn.net
(Source Discussion / 原帖讨论: 光纤光栅解调仪的最大采样频率是多少,能不能用在动态场景测试里)
