Why is chemical stripping (e.g., concentrated sulfuric acid) cleaner for Polyimide coatings?
Chemical stripping, such as with concentrated sulfuric acid for polyimide coatings, is generally considered cleaner than mechanical stripping due to the fundamental differences in their mechanisms.
Mechanical stripping relies on physical force, which can inadvertently create microscopic damage, nicks, or scratches on the delicate silica fiber surface. These imperfections can lead to increased fiber attenuation, reduced mechanical strength, and potential failure points, especially when the fiber is subjected to stress or used for applications like Fiber Bragg Grating (FBG) inscription. Mechanical methods can also leave behind residual coating fragments or an uneven surface.
In contrast, chemical stripping uses a solvent that chemically reacts with and dissolves the polyimide coating. Concentrated sulfuric acid, for example, hydrolyzes the polyimide polymer chains, effectively breaking them down and allowing for a clean, uniform removal of the coating without introducing physical damage to the fiberās silica surface. This results in a pristine fiber surface, which is crucial for maintaining the optical and mechanical integrity of the fiber, particularly for high-performance applications.
For applications requiring polyimide-coated fibers or FBGs, we offer:
- OFSCNĀ® Polyimide Fiber Bragg Gratings / Fiber Bragg Grating Strings (bare)
- OFSCNĀ® 300 SM Polyimide Optical Fiber
Here is an image related to our polyimide optical fiber:
