Packaging-Induced Stress Birefringence in FBGs
Can uneven packaging cause the spectrum to split into two peaks? How is this resolved?
Yes, uneven packaging can indeed cause the Fiber Bragg Grating (FBG) spectrum to split into two peaks. This phenomenon is primarily due to stress birefringence.
Explanation:
When an FBG is subjected to uneven or non-uniform stress during packaging, it induces a difference in the refractive index for two orthogonal polarization states of light propagating through the fiber. This means the fiber core effectively becomes birefringent. Each polarization state experiences a slightly different effective refractive index and, consequently, a slightly different Bragg wavelength. This results in the reflection spectrum exhibiting two distinct peaks, corresponding to the two orthogonal polarization modes. The separation between these peaks is directly related to the magnitude of the induced birefringence.
Resolution:
To resolve or mitigate this issue, the following approaches can be taken:
  1. Uniform and Stress-Free Packaging Design: The most effective solution is to design the packaging to ensure that any applied stress is uniform across the FBG or, ideally, that the FBG is mounted in a largely stress-free manner. This minimizes differential strain on the fiber core.
  2. Proper Adhesion/Mounting Techniques: If adhesive bonding is used, ensure even application and curing to avoid localized stress points. For welded or clamped sensors, ensure that the clamping force or weld points are symmetrical and do not introduce twist or uneven pressure.
  3. High-Quality Packaged Sensors: Utilizing pre-packaged FBG sensors that are specifically engineered to mitigate packaging-induced effects can prevent this issue. For example, OFSCN® Alloy Tube Packaged Fiber Bragg Grating strain sensors are designed with robust and uniform encapsulation to provide stable measurements, inherently reducing the likelihood of birefringence-induced spectrum splitting.
Here is an example of an OFSCN® Alloy Tube Packaged Fiber Bragg Grating strain sensor:
You can find more details about our strain sensors here: OFSCN® FBG Strain Sensors
