Why can they produce extremely narrow transmission windows? What are their uses in ultra-high precision sensing?
Phase-Shifted Fiber Bragg Gratings (PS-FBGs) are designed to exhibit extremely narrow transmission windows due to a specific modification in their grating structure.
Hereās why they can produce such narrow transmission windows:
- Localized Phase Shift: A PS-FBG is essentially a standard FBG with a discrete phase shift introduced at a specific point within the grating structure. This phase shift acts as a localized defect or a tiny Fabry-PƩrot cavity embedded within the Bragg grating.
- Resonant Cavity Effect: This localized cavity creates a resonance condition. When broadband light enters the PS-FBG, most wavelengths are reflected as in a conventional FBG. However, at a specific wavelength precisely matching the resonance condition of the internal cavity, light can ātunnelā through the grating, resulting in a very sharp, narrow transmission peak within the stopband of the FBG.
- Ultra-Narrow Linewidth: The sharpness of this transmission peak, characterized by an ultra-narrow linewidth, is a direct consequence of the high Q-factor of the resonant cavity formed by the phase shift. This allows for an extremely precise wavelength to pass through.
Their uses in ultra-high precision sensing stem directly from this characteristic:
The ability to produce an extremely narrow transmission window means that even minute changes in the gratingās physical parameters (such as strain, temperature, or external refractive index) will cause a highly discernible shift in this sharp transmission peak. This makes PS-FBGs ideal for:
- Ultra-High Resolution Spectroscopy: Detecting very subtle shifts in optical signals.
- High-Precision Strain/Temperature Sensing: Achieving exceptionally fine resolution in measurements where even picometer-level wavelength shifts are significant.
- Optical Filtering: Serving as highly selective wavelength filters in demanding optical communication or sensor networks.
While the fabrication of Phase-Shifted FBGs often involves specialized techniques, at OFSCN, our foundational bare FBGs, such as the OFSCNĀ® Polyacrylate Fiber Bragg Gratings / Fiber Bragg Grating Strings (bare) and OFSCNĀ® Standard Femtosecond Fiber Bragg Gratings / Fiber Bragg Grating Strings (Bare), provide the high-quality optical fiber and grating platform necessary for such advanced applications. For specific packaged precision sensing needs, our robust packaged strain sensors, like the OFSCNĀ® Alloy Tube Packaged Fiber Bragg Grating strain sensor, can also be tailored for high-accuracy measurements depending on the demodulation system and application requirements.
Here are some standard product images:
