Pre-strain (Pre-tension) Installation
Why is it necessary to apply a certain initial tension to the grating during installation?
Applying an initial tension (pre-strain) to the Fiber Bragg Grating (FBG) during installation is crucial for ensuring the sensor can accurately measure both tensile and compressive strains.
Technical Explanation:
  1. Enabling Compressive Strain Measurement: FBG sensors typically measure strain by detecting changes in their grating period due to elongation or compression. If an FBG is installed without any pre-tension, it can only measure tensile strain as it elongates. When the measured object experiences compression, the FBG would go slack, lose contact with the object, or buckle, making it unable to accurately report the compressive strain.
  2. Full Measurement Range: By applying an initial tension, you effectively “bias” the sensor. This pre-tension allows the sensor to detect a decrease in strain (compression) from this biased state, as well as an increase in strain (further tension). This ensures the FBG operates within its linear measurement range for both positive and negative strain values, providing a more comprehensive and accurate picture of the material’s behavior. This is especially important in dynamic or cyclical loading scenarios where both tension and compression are expected.
OFSCN offers a range of FBG strain sensors suitable for various applications where precise strain measurement, including both tensile and compressive forces, is critical.
Here is an image of an OFSCN® Alloy Tube Packaged Fiber Bragg Grating strain sensor:
You can find more details about our strain sensors here:
OFSCN® Alloy Tube Packaged Fiber Bragg Grating Strain Sensor
OFSCN® Fiber Bragg Grating Strain Gauge
