Pressure Resistance of FBG Sensor - 180 MPa FBG Sensor - Internal Pressure, External Pressure, Lateral Pressure of 9000 N - DCYS - ofscn.net
This article analyzes the advantages and benefits brought by good pressure resistance in FBG sensors, including the expansion of application environments and the convenience in engineering construction. It also introduces the "OFSCN® Capillary Seamless Steel Tube Series Fiber Bragg Grating Sensor"  produced by DCYS (These series of products are all high-pressure-resistant fiber optic gratingFBG sensors used for temperature, strain, or stress measurements). It shows part of the physical illustrations and parameters.
This is a companion discussion topic for the original entry at https://www.ofscn.net/fbg-baike/133-compressive-strength.html
The topic of high-pressure resistance in Fiber Bragg Grating (FBG) sensors is critical for applications in deep-sea environments, oil and gas downhole monitoring, and high-pressure hydraulic systems.
Technical Analysis of Pressure Resistance in FBG Sensors
The pressure resistance of an FBG sensor is primarily determined by its encapsulation material and structural design. Standard FBG sensors with polymer coatings or adhesive-based packaging often fail under high pressure due to material deformation or “creep,” which shifts the Bragg wavelength and introduces measurement errors.
The OFSCN® Capillary Seamless Steel Tube Series Fiber Bragg Grating Sensors address these challenges by utilizing a specialized all-metal seamless tube encapsulation. This design offers several technical advantages:
  1. High External Pressure Resistance: The seamless stainless steel or alloy tube provides a rigid protective shell that can withstand external pressures up to 180 MPa, preventing the internal fiber from being crushed or experiencing transverse strain interference.
  2. Lateral Load Durability: These sensors can handle lateral pressures of up to 9000 N, making them suitable for embedding in concrete, soil, or mechanical structures where heavy loading is expected.
  3. Stability: By eliminating adhesives in the sensing section (all-metal fusion or mechanical clamping), the sensor maintains high precision without the signal drift typically caused by high-pressure environments.
Related Products and Specifications
Based on the requirements for high-pressure and high-load environments, we recommend the following professional solutions:
To provide a more accurate technical recommendation for your specific project, could you please clarify the following:
  1. Is the pressure you need to withstand internal (inside a pipe) or external (hydrostatic/ambient pressure)?
  2. What is the maximum operating temperature in your environment?
