cmh
Last Updated: 20 January 2026
In the Structural Health Monitoring (SHM) of critical infrastructure such as hydraulic dams, rail transit tunnels, and large-scale bridges, the survival rate of the monitoring system is a core metric of concern for the engineering community. Since fiber optic cables are difficult to replace once embedded within concrete structures, their environmental durability directly dictates the continuity of monitoring data.
This is a companion discussion topic for the original entry at https://www.ofscn.org/encyclopedia/522-sst-cables-two-layer-01.html
The durability of monitoring systems in Structural Health Monitoring (SHM) is indeed critical, especially when sensors are embedded in concrete and become inaccessible for replacement. To ensure long-term survival in such harsh environments, the mechanical protection of the optical fiber is the primary technical challenge.
For the infrastructure monitoring scenarios described (dams, tunnels, and bridges), OFSCN® Double-Layer High-Temperature Downhole Fiber Optic Cable provides a robust solution. Its design philosophy centers on redundant mechanical shielding and hermetic sealing.
Key Technical Advantages:
- Redundant Protection: By utilizing a double-layer seamless tube structure (typically 316L stainless steel or 825 alloy), the fiber is shielded from the high alkaline environment of concrete and the high mechanical stresses during the pouring and curing process.
- Geometric Stability: The outer layer (default 6.35mm diameter) provides the necessary rigidity to withstand crushing forces, while the inner layer (3.6mm diameter) ensures the optical fibers remain in a stable, low-strain environment.
- Hermetic Sealing: Seamless tube technology prevents moisture and chemical ingress, which is the leading cause of hydrogen darkening and fiber degradation in long-term infrastructure projects.
Visual Reference:
This type of cable is often used as a distributed sensor for strain or temperature monitoring, compatible with Brillouin (BOTDA/BOTDR) or Rayleigh (OFDR) scattering-based interrogators.
Detailed technical specifications can be found here:
If you are evaluating specific parameters for a dam or tunnel project, such as the required outer diameter or the number of fiber cores needed, please feel free to provide the environmental details for further technical analysis.
