The Role of “Filling Compounds” in Packaging
Is it necessary to fill the steel tube with specific substances to assist heat transfer or vibration damping?
It is indeed a valid technical consideration to fill steel tubes with specific substances to enhance performance for certain applications.
Regarding heat transfer:
If the primary purpose is rapid and accurate temperature sensing, a thermally conductive filling compound can significantly improve the thermal coupling between the outer steel tube and the optical fiber within. This ensures that the fiber Bragg grating (FBG) sensor’s temperature response is swift and precisely reflects the external environment. However, for applications where the steel tube primarily serves to protect the fiber from high temperatures, the choice of tube material (e.g., 316L stainless steel, 825 alloy for OFSCN® 650/700°C Seamless Steel Tube Fiber Cable) and the use of high-temperature resistant optical fibers (e.g., gold-coated fiber) are the main factors in achieving temperature resistance.
Regarding vibration damping:
Filling compounds can provide mechanical stability to the optical fiber inside the steel tube. This is particularly important for strain sensing applications or in environments with significant mechanical vibration. A suitable filling can dampen vibrations, reduce micro-bending losses on the fiber, and protect the bare fiber from external mechanical stresses, thereby improving the accuracy and longevity of the sensor.
The necessity of such filling compounds ultimately depends on the specific application’s requirements for sensing accuracy, response speed, and environmental resilience.
OFSCN offers various types of robustly packaged seamless steel tube fiber cables, designed for different temperature ranges and applications where the steel tube provides significant protection and stability to the internal optical fiber(s). An example of our seamless steel tube fiber cable is shown below:
You can find more detailed technical parameters on our products here:
