What are "Corrosion-resistant" fiber optic patch cords?
In chemical plant environments with acid mist, what kind of jacket materials (such as PTFE) can protect the fiber?
For chemical plant environments involving acid mist, standard PVC or PE jackets are often insufficient as they may degrade over time when exposed to corrosive vapors.
To provide a professional recommendation, I need to clarify a few technical requirements regarding your application environment:
  1. Chemical Concentration & Type: Besides “acid mist,” are there specific high concentrations of strong acids (like sulfuric or nitric acid) or organic solvents involved?
  2. Temperature Range: What is the maximum ambient temperature the cable will encounter? (e.g., Room temperature, 120°C, 300°C, or higher?)
General Technical Insights on Corrosion-Resistant Materials
In industrial fiber optic sensing and communication, the following jacket materials are typically used for protection against chemical corrosion:
  • PTFE/FEP/PFA (Fluoropolymers): These are the most common “corrosion-resistant” materials. They are virtually inert to most acids and alkalis and can handle high temperatures (up to 260°C for PTFE).
  • Polyimide (PI): Often used as a primary coating for the fiber itself. While excellent for high temperatures (up to 300°C), it also offers good chemical resistance in specialized sensing applications.
  • Stainless Steel (304/316L): For extreme mechanical and chemical protection, OFSCN® uses seamless stainless steel tubes. While stainless steel is resistant to many chemicals, in specific high-chloride or highly acidic environments, we may add an outer fluoropolymer jacket over the steel tube.
Recommended OFSCN® Solutions
Depending on your temperature requirements, we recommend the following professional-grade armored patch cords which utilize Seamless Stainless Steel Tubes as the primary protective layer. These can be customized with chemical-resistant outer jackets:
  1. For Mid-High Temperatures (Up to 300°C):
    OFSCN® 300℃ Fiber Optic Patch Cord
    This product uses a 0.9mm seamless stainless steel tube which provides excellent hermetic protection for the fiber.
  2. For Extreme Mechanical Environments:
    OFSCN® 2.0mm Steel Wire Rope Fiber Optic Patch Cord
    This features an all-metal structure (stainless steel tube + galvanized steel wire) which offers maximum physical protection in harsh industrial plants.
Product Images:
Once you provide the specific temperature and acid type, I can suggest the most appropriate jacket material and armoring combination for your project.
