Why can’t standard electrical pliers be used to strip the coating off an optical fiber?
Standard electrical pliers cannot be used to strip the coating off an optical fiber for several critical technical reasons related to the physical properties of glass fiber and the precision required in fiber optics:
1. Dimensional Precision and Tolerance
Optical fibers are extremely thin and fragile. A standard single-mode fiber has a glass cladding diameter of 125 microns (μm), while the outer buffer coating (usually acrylate) is typically 250 microns.
- Electrical Pliers: Designed for copper wires, they have much larger tolerances and “V” or “U” notches that are far too coarse.
- Fiber Strippers: Tools like the [Miller Stripper] feature laser-drilled, precision-ground holes designed to leave exactly 125μm of space. Using electrical pliers would either fail to remove the coating or, more likely, crush the glass fiber instantly.
2. Surface Micro-cracks and Tensile Strength
Glass is highly sensitive to surface defects. Even if electrical pliers managed to remove the coating without breaking the fiber immediately, the metal jaws would inevitably scratch the surface of the glass cladding.
- These micro-cracks act as stress concentration points.
- Under the slight tension or bending required for splicing or connectorization, a scratched fiber will undergo “brittle fracture” and snap. Precision fiber strippers are designed to glide over the cladding without making direct mechanical contact with the glass itself.
3. Signal Integrity and Optical Loss
If the cladding is nicked or scratched by improper tools, it can cause evanescent wave leakage or alter the total internal reflection properties of the fiber. This leads to high insertion loss or back-reflection (ORL), which degrades the performance of the optical network or the accuracy of an FBG sensor.
4. Material Differences
Electrical pliers are designed to cut or grip ductile materials like copper or aluminum. Optical fiber is a ceramic/glass material that does not deform; it only maintains integrity or shatters.
For professional fiber preparation, especially when working with FBG sensors or specialty optical fibers, we always utilize dedicated stripping tools to ensure the long-term reliability of the fiber.
