What are Heat-Shrink Protection Sleeves?
How do heat-shrink sleeves restore mechanical strength and moisture resistance at the splice point?
Heat-shrink protection sleeves restore mechanical strength and moisture resistance at the splice point through a combination of material properties and the shrinking process.
Mechanical Strength Restoration:
  1. Reinforcement Rod: Many splice protection sleeves incorporate a steel or ceramic strength member. This rod runs parallel to the spliced fibers, providing a rigid support structure that helps to bear tensile and compressive loads, preventing the delicate splice from bending or breaking.
  2. Adhesive/Hot-Melt Tube: Inside the heat-shrink sleeve, there is typically an inner adhesive or hot-melt tube. When heated, this material melts and flows, encapsulating the bare fiber and the splice point. Upon cooling, it solidifies, creating a strong, uniform bond that fills any voids and mechanically secures the splice.
  3. Shrinking Outer Sleeve: The outer sleeve, made from a cross-linked polyolefin or similar polymer, shrinks radially when heated. This shrinking action applies a compressive force around the adhesive and the fibers, compacting the entire assembly into a single, robust unit. This tight fit provides a protective shell that significantly increases the splice’s resistance to external mechanical stresses like vibration, bending, and impact.
Moisture Resistance Restoration:
  1. Watertight Seal: The melted inner adhesive material forms a hermetic, watertight seal around the optical fiber and the splice joint. This seal effectively blocks the ingress of moisture, humidity, and other environmental contaminants.
  2. Physical Barrier: The shrunk outer sleeve itself acts as a robust physical barrier, protecting the encapsulated splice from direct exposure to water, dust, chemicals, and other corrosive elements in the operating environment.
This comprehensive encapsulation ensures that the splice point regains mechanical strength comparable to, or sometimes even exceeding, the original fiber’s coating, and is effectively sealed against environmental degradation. These sleeves are crucial for ensuring the long-term reliability of fusion splices in various applications, including those using OFSCN® optical fibers.
For example, our OFSCN® G.652D Optical Fiber, a standard single-mode fiber, would typically utilize such splice protection in its deployment.
Here is an image related to optical fibers:
