What are LC-type miniaturized connectors?
In space-constrained sensor integration boxes, how do LC connectors facilitate high-density cabling and cable management?
LC (Lucent Connector) connectors are specifically designed for high-density environments where space is at a premium. In the context of fiber optic sensing integration, such as FBG (Fiber Bragg Grating) sensor terminal boxes or interrogator interfaces, they facilitate cable management through several key technical features:
1. Small Form Factor (SFF) Design
The LC connector uses a 1.25mm ceramic ferrule, which is exactly half the size of the 2.5mm ferrule used in standard FC or SC connectors. This allows for twice the packing density on a patch panel or within a sensor integration box. For instance, a standard rack unit (1U) that might only hold 24 FC ports can easily accommodate 48 or even 96 LC ports.
2. RJ-45 Style Latch Mechanism
LC connectors utilize a “push-and-latch” mechanism similar to an Ethernet (RJ-45) plug. This provides a secure, audible click when engaged, ensuring a reliable connection even in crowded environments where tactile feedback is necessary. This design prevents accidental disconnection caused by pulling on adjacent cables during maintenance.
3. Ease of Duplexing
LC connectors are easily clipped together to form Duplex LC connectors. This is particularly useful for FBG sensing systems that require a “loop-back” configuration or dual-channel monitoring, as it treats two fibers as a single unit, simplifying cable routing and reducing the “spaghetti” effect of individual fiber strands.
4. Integration with OFSCN® Products
While LC connectors are excellent for high-density indoor management, they are typically rated for standard industrial temperatures. At Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN), we offer standard fiber patch cords with LC interfaces for general-purpose connectivity:
Typical appearance of standard patch cord configurations:
Technical Note: If your sensor integration box is exposed to extreme temperatures (above 65°C), please note that standard LC connectors may not be suitable. For such environments, we generally recommend specialized high-temperature connectors (such as our 120°C or 200°C rated FC versions), as LC-type miniaturized connectors in high-temperature variants are less common in standard stock.
For detailed specifications regarding dimensions and fiber types compatible with LC interfaces, you may refer to the product link above.
