What are "Single-mode" and "Multi-mode"?
In simple terms, what is the biggest difference in how these two types of fiber transmit light?
In simple terms, the biggest difference between single-mode and multi-mode fiber lies in the pathway (mode) through which light travels, which is primarily determined by the diameter of the fiber’s core.
1. Light Transmission Paths
  • Single-mode Fiber (SM): It has a very small core (typically 9μm). Because the core is so narrow, light can only travel in a single, straight path (the fundamental mode). This eliminates “modal dispersion,” allowing signals to travel much further with high clarity.
  • Multi-mode Fiber (MM): It has a much larger core (typically 50μm or 62.5μm). This allows light to enter at multiple angles and travel along multiple paths (modes) simultaneously. However, because different paths have different lengths, the light pulses spread out over distance, which limits the transmission range.
2. Core Comparison in OFSCN® Products
In high-temperature environments, DCYS (OFSCN) provides specialized fibers where this core difference is critical for sensing and communication:
Standard Product Image:
3. Key Summary
Feature Single-mode (SM) Multi-mode (MM)
Core Diameter ~9μm 50μm or 62.5μm
Light Paths Single path Multiple paths
Distance Long distance (kilometers) Short distance (usually <2km)
Common Use Telecom, FBG Sensing LANs, Short-range data centers
For more detailed technical specifications, you can refer to:
OFSCN® Optical Fibers Category
