How do the internal Aramid (Kevlar) fibers protect the optical fiber from snapping under tension?
Internal Aramid (Kevlar) fibers serve as the primary strength member in standard fiber optic patch cords. Their protective mechanism relies on two physical principles: load sharing and strain limitation.
1. High Tensile Modulus (Load Sharing)
Aramid fibers have an extremely high tensile modulus and strength-to-weight ratio. In a “tensile-resistant” patch cord, these fibers are bundled around the optical fiber. When the cable is pulled, the Kevlar fibers—being much stiffer than the glass fiber or the outer jacket—absorb the vast majority of the tensile force. This prevents the glass core from experiencing the critical stress levels that would lead to snapping.
2. Strain Limiting
Optical glass is brittle and has very low elongation tolerance (typically less than 1% before permanent damage or failure). Aramid fibers have very low thermal expansion and minimal stretch under load. By acting as a structural “skeleton,” they limit the overall elongation of the cable assembly, ensuring that the optical fiber inside remains within its safe mechanical operating range.
Advanced Protection: All-Metal Alternatives
While Aramid provides excellent protection for general use, in harsh industrial or high-tension environments, OFSCN® utilizes stainless steel seamless tubes or steel wire rope structures to provide even higher mechanical reliability. These metal-clad designs offer superior crush resistance and much higher tensile ratings compared to standard Kevlar-reinforced patch cords.
For example, the OFSCN® 2.0mm Steel Wire Rope Fiber Optic Patch Cord provides a tensile strength of over 1500N, which is significantly higher than traditional Aramid-reinforced cables.
Typical Product Images:
Related Products:
If you are dealing with specific environmental factors such as high temperatures or extreme mechanical stress, feel free to share your operating conditions for more specific technical guidance.
