Under what circumstances does light in a jumper fiber exhibit a “color shift” phenomenon?
In optical physics, the “color” of light is determined by its optical frequency (or vacuum wavelength \lambda = c / \nu). In conventional fiber transmission (such as weak or low-power lasers), the fiber operates in the linear optics regime, and the light wave’s frequency remains unchanged.
When light “changes color” in a fiber or patch cord, the physical essence is that the incident light generates new frequency/wavelength components through nonlinear optical effects, or the spectrum undergoes extremely broad expansion.
The core mechanisms and conditions for “color” change in fiber patch cords are as follows:
I. Physical Mechanisms of “Color” Change (Nonlinear Effects)
Silicon dioxide (\text{SiO}_2) fibers have extremely small core mode field areas (e.g., the effective mode field area of standard single-mode fiber is A_{\text{eff}} \approx 50\text{--}80\ \mu\text{m}^2). When extremely high power density light fields are injected, the material’s nonlinear susceptibility (primarily third-order nonlinear susceptibility \chi^{(3)}) is excited, altering the light’s wavelength mainly through the following pathways:
Stimulated Raman Scattering (SRS)
- Physical Process: Incident high-power photons (pump light) interact with the lattice vibrations (optical phonons) of silicon dioxide molecules, losing some energy to molecular vibrations, thus down-converting to new photons with lower frequency and longer wavelength (Stokes light).
- Color Change Manifestation: Monochromatic lasers shift down to one or more discrete new wavelengths within the fiber (the Raman peak frequency shift in silica fibers is approximately 13.2\ \text{THz}), exhibiting a color change towards longer wavelengths (redshift).
Spectral Broadening Induced by Self-Phase Modulation (SPM) and Cross-Phase Modulation (XPM)
- Physical Process: Based on the optical Kerr effect, the refractive index of the fiber changes with the instantaneous local light intensity:n(I) = n_0 + n_2 I
- Color Change Manifestation: Ultrafast laser pulses, driven by time-varying light intensity, undergo nonlinear phase modulation (optical frequency chirp), causing the originally monochromatic/narrowband spectrum to broaden significantly symmetrically or asymmetrically on both sides.
Four-Wave Mixing (FWM)
- Physical Process: When phase-matching conditions are met, two or three photons of different frequencies interact and annihilate, simultaneously exciting two new frequency components (satisfying energy conservation \nu_1 + \nu_2 = \nu_3 + \nu_4).
- Color Change Manifestation: Symmetrically distributed new wavelength components are generated on both sides of the incident light.
Supercontinuum Generation (SCG — “White Light/Rainbow” Phenomenon)
- Physical Process: When high-energy ultrashort pulses (such as femtosecond or picosecond lasers) are injected into the fiber, multiple nonlinear effects, including SPM, SRS, FWM, higher-order dispersion, and soliton self-frequency shift, act together in a cascaded manner.
- Color Change Manifestation: The incident monochromatic laser light is extremely broadened into a continuous spectrum spanning the visible to near-infrared range. Visually, the originally monochromatic light beam transforms into colorful “white light” at the fiber end face or where light leaks laterally.
II. Extreme Conditions Required for “Color” Change
For conventional single-mode patch cords (e.g., fiber patch cords using G.652D or G.657 core fibers), which are typically only a few meters long, observing nonlinear “color” change directly within such short lengths requires satisfying the following stringent physical conditions:
- Extremely High Peak Power Density
The nonlinear accumulation in a few meters of fiber is weak for conventional milliwatt (\text{mW}) or watt (\text{W}) continuous light; typically, peak powers in the kilowatt (\text{kW}) to megawatt (\text{MW}) range are required (e.g., from pulsed lasers, femtosecond/picosecond ultrafast laser systems). - Dispersion and Phase Matching
For Four-Wave Mixing and soliton dynamics, the pump light wavelength usually needs to be near the fiber’s zero-dispersion wavelength (ZDW) or in the anomalous dispersion regime to achieve efficient nonlinear energy conversion.
In conventional fiber sensing, optical communication, and industrial measurement applications, such as using OFSCN® Standard Fiber Patch Cord, the transmitted optical power is typically far below the nonlinear threshold. The fiber always operates within the linear transmission regime and does not exhibit color change or wavelength drift.
