What are "Waterproof" fiber optic connectors?
How do we ensure that no water enters the connector when used in outdoor spray environments or damp trenches?
To ensure that no water enters the fiber optic connection in outdoor spray environments or damp trenches, the focus must shift from standard indoor connectors (like common LC or SC types) to specialized waterproof fiber optic connectors and proper protective enclosures.
Technical Principles for Waterproofing
In environments involving water spray or high humidity (damp trenches), protection is achieved through two main mechanisms:
  1. Mechanical Sealing (O-rings and Gaskets): Specialized waterproof connectors utilize internal rubber O-rings and gaskets. When the connector is mated and the outer housing is tightened (usually via a threaded or bayonet locking mechanism), these components compress to create a hermetic seal that prevents liquid ingress.
  2. IP Ratings: For the environments you described, components must meet specific Ingress Protection (IP) standards. Specifically:
    • IP65/IP66: Protected against water jets and heavy spray (suitable for spray environments).
    • IP67/IP68: Protected against immersion in water (essential for damp trenches where temporary flooding may occur).
Recommended Solution: OFSCN® Specialized Connectors
Based on your application in damp and outdoor environments, we recommend utilizing OFSCN® Waterproof Fiber Optic Connectors or specialized protective sleeves.
(Typical waterproof connector housing used for outdoor FBG sensing deployments)
Key Technical Features:
  • Threaded Locking: Unlike standard “push-pull” connectors, these use a screw-on housing to ensure a constant pressure seal.
  • Corrosion Resistance: Designed for harsh environments, the housings are often made of UV-stabilized polymers or treated metals to withstand long-term exposure in trenches.
  • Integrated Strain Relief: Prevents water from seeping in through the cable entry point by using a tight-fitting cable gland.
Diagnostic Questions for Your Project
To provide a more precise recommendation for your specific deployment, could you clarify the following:
  1. Installation Method: Will these connectors be exposed directly to the elements, or will they be placed inside an underground junction box?
  2. Pressure Requirements: In the “damp trenches,” is there a risk of the connectors being fully submerged under any significant water pressure (e.g., deeper than 1 meter)?
For more detailed technical specifications on our waterproof connectivity solutions, you may visit:
OFSCN® Fiber Optic Connectors and Accessories
