What if I lose the certificate? Can I retrieve the sensor parameters using the serial number?
When the factory calibration certificate is lost in the field of Fiber Bragg Grating (FBG) sensing engineering and standardized manufacturing systems, the original calibration parameters can be fully retrieved using the sensor’s factory serial number (SN).
The technical traceability principles, operational procedures, and alternative solutions are as follows:
I. Parameter Retrieval Mechanism Based on Serial Number (SN)
Industrial-grade fiber Bragg grating sensors implement a full lifecycle quality traceability mechanism of Single-piece Tracking:
- Unique Identification Location:
When the sensor leaves the factory, the serial number (SN) is typically marked on the laser-etched area of the outer protective sleeve, the label on the tail boot of the fiber optic connector (e.g., FC/APC), or the product packaging nameplate. - Factory Database Archiving:
During factory quality inspection and calibration, the manufacturer archives the original physical and optical parameters for each sensor into the factory database. These parameters usually include:- Initial Bragg center wavelength (\lambda_0, typically measured at a standard ambient temperature of 25\ ^\circ\text{C} and in a free, stress-free state).
- Reflection spectrum quality parameters: Reflectivity, 3\text{ dB} bandwidth, Side Mode Suppression Ratio (SMSR).
- Calibration fitting formulas and coefficients:
- Temperature sensors: Factory calibration polynomial (usually a quadratic fit: T = a \cdot (\Delta\lambda)^2 + b \cdot \Delta\lambda + c, with units often in ^\circ\text{C}/\text{pm}).
- Strain/Stress/Displacement sensors: Linear calibration sensitivity coefficient (units are \mu\varepsilon/\text{pm}, \text{MPa}/\text{pm}, or \mu\text{m}/\text{pm}, respectively).
- Retrieval Method:
Simply provide the complete serial number (SN) on the sensor to the original manufacturer’s technical support team. The manufacturer can then retrieve the original factory calibration records and issue an electronic copy of the “Factory Calibration Certificate” or provide a demodulator configuration file.
II. Remedial Measures if the Serial Number (SN) is Worn or Unidentifiable
If the sensor’s label has detached or the laser etching has become blurred due to harsh operating conditions, making the serial number illegible, the following two engineering methods can be employed:
Method A: Reverse Lookup Based on Initial Center Wavelength (\\lambda_B)
If the specific batch or project order to which the sensor belongs can be determined:
- Connect the sensor to a fiber Bragg grating demodulator.
- Under standard room temperature conditions (e.g., a stable 20\ ^\circ\text{C} \sim 25\ ^\circ\text{C} controlled environment) with the sensor completely free from any stress, read the current reflection center wavelength \lambda_B.
- Since sensors in a wavelength-division multiplexing (WDM) system within the same batch usually have preset, non-overlapping center wavelength channels (e.g., distributed at 2\text{ nm} or 3\text{ nm} intervals), the manufacturer can accurately cross-reference the measured wavelength with the historical factory ledger for that batch to identify the corresponding sensor number and calibration coefficients.
Method B: Factory Re-calibration
If neither the serial number nor historical order records are available, or if the sensor has been in service for an extended period under harsh conditions (e.g., long-term exposure to ultra-high temperatures above 300\ ^\circ\text{C}, or severe alternating stress fatigue environments):
- Micro-residual stress release or creep in the packaging material may occur within the fiber material, leading to slight drift in the original factory parameters.
- In such cases, the most rigorous approach is to send the sensor back to the original manufacturer or a qualified calibration laboratory for multi-point re-calibration (using a high-precision constant temperature bath/tube furnace for temperature sensors; using a microcomputer-controlled electronic universal testing machine for strain sensors). This process involves re-fitting and establishing a calibration equation between the input physical quantity and the wavelength shift \Delta\lambda.
