What is a "Fiber Cleaver"?
Why is the flatness of the cleaved end-face so critical to the overall connection quality?
The flatness of the cleaved end-face is critical because it directly dictates the efficiency of light transmission and the physical integrity of the connection. In optical fiber technology, specifically when working with Fiber Bragg Grating (FBG) sensors or standard communication fibers, the end-face serves as the interface for light entry and exit.
Here are the technical reasons why flatness is essential:
1. Minimization of Insertion Loss
If the end-face is not perfectly flat (i.e., it has a high “cleave angle” or surface irregularities), the light exiting one fiber will not enter the core of the receiving fiber or device efficiently. Any tilt or unevenness causes the light beam to refract at an unintended angle, leading to power loss, known as Insertion Loss.
2. Reduction of Back Reflection (Return Loss)
A rough or angled end-face creates a mismatch in the refractive index interface. This causes a portion of the light to reflect back toward the source. In high-precision sensing systems using OFSCN® Fiber Bragg Grating (FBG) Products, excessive back reflection can create “noise” that interferes with the FBG signal, reducing the accuracy of temperature or strain measurements.
3. Core Alignment Accuracy
Optical fiber cores are extremely small (typically 9 microns for single-mode fiber). If the cleave is not flat and perpendicular (ideally < 0.5 degrees), the cores will not align perfectly during fusion splicing. This results in a weak splice point that is prone to high attenuation or mechanical failure.
4. Prevention of Physical Gaps
In mechanical connectors, a non-flat cleave prevents the two fiber ends from making physical contact. This creates an air gap which triggers Fresnel reflection, significantly degrading the quality of the optical signal.
For high-performance applications, such as those involving OFSCN® FBG Interrogators, using a high-precision fiber cleaver is mandatory to ensure the reliability of the entire sensing network.
If you are currently setting up a system, could you specify if you are preparing fibers for fusion splicing or for mechanical connector assembly? This will help determine the required cleave tolerance for your project.
