What is a "Mechanical Splice Connector" (Cold Splice)?
In an emergency where no fusion splicer is available, how can you quickly reconnect a broken optical fiber?
In emergency situations where a fusion splicer is unavailable, you can quickly reconnect a broken optical fiber using a Mechanical Splice Connector, also commonly referred to as a “Cold Splice.”
Technical Explanation
A mechanical splice is a device that aligns the two fiber ends and holds them in place with a mechanical clamping mechanism and an internal index-matching gel. Unlike fusion splicing, which uses an electric arc to melt the glass together, a mechanical splice relies on physical alignment and optical coupling fluid to minimize signal loss and reflection.
Key Characteristics
  1. Fast Deployment: Requires only basic fiber preparation tools (stripper, cleaver, and alcohol) and can be completed in approximately 1 to 2 minutes.
  2. No Power Required: Ideal for remote field repairs or emergency maintenance in harsh environments where electricity for a fusion splicer is unavailable.
  3. Index-Matching Gel: The internal gel has a refractive index similar to the glass core, which helps reduce insertion loss (typically < 0.2dB to 0.5dB) and back-reflection.
Limitations compared to Fusion Splicing
While excellent for emergencies, mechanical splices generally have:
  • Higher insertion loss and lower return loss.
  • Lower long-term mechanical strength (tensile strength).
  • Higher sensitivity to temperature fluctuations over long periods.
For high-reliability FBG sensing applications or permanent infrastructure, DCYS (OFSCN) generally recommends fusion splicing. However, for quick restoration of an optical link, the mechanical splice is the standard industry solution.
For more technical details on fiber optic connection technologies, you may refer to the OFSCN Knowledge Base.
