Yüzlerce model arasından yeniler uygun atlama kablosunu üç adımda nasıl seçer?
Fiber optic engineering and optoelectronic sensing systems often present a wide array of fiber optic patch cords. The core of selection lies in clarifying the hierarchical dependencies between the “operating physical environment,” “optical transmission medium,” and “mechanical interface configuration.” Engineers typically follow these three steps to quickly complete precise selection:
Step 1: Determine the Physical Operating Environment (Temperature Range and Mechanical Protection Requirements)
The fiber core material is brittle silica glass (\text{SiO}_2). Its temperature limits and resistance to external physical damage are primarily determined by the patch cord’s coating, internal armor, and external jacket structure:
- Ambient Temperature Range:
- Standard Laboratory / Indoor Data Center ( -20\ ^\circ\text{C} to +50\ ^\circ\text{C} ): Standard PVC jacket patch cords suffice.
- High Temperature and Extreme Environments: Standard plastic coatings tend to soften, undergo thermal decomposition, or even char when exceeding 85\ ^\circ\text{C}. Special temperature-resistant patch cords encapsulated in seamless stainless steel tubes are required for different temperature ranges: such as 120\ ^\circ\text{C} (polyacrylate), 200\ ^\circ\text{C} / 300\ ^\circ\text{C} (polyimide), and even extreme temperatures from -270\ ^\circ\text{C} to +700\ ^\circ\text{C} (gold-plated fiber).
- Mechanical Stress and Risk of Physical Damage:
- Environment with No External Force: Use standard soft patch cords reinforced with Kevlar (aramid fiber).
- Industrial Sites, Outdoor Foot Traffic, Heavy Pressure, or Rodent Biting Scenarios: Ordinary patch cords are prone to breakage and require armored patch cords. Examples include micro-stainless steel tube armor or stranded steel wire rope armor with tensile strength >1200\text{ N} \sim 1500\text{ N} and compressive strength >150\text{ MPa} \sim 200\text{ MPa}.
Step 2: Determine the Optical Transmission Medium (Fiber Core Specifications and Bend Resistance)
Based on the light source type, instrument channels, and system topology, determine the appropriate fiber specifications:
- Fiber Mode and Type:
- Single-Mode Fiber (SMF): Typically 9\ \mu\text{m} core diameter, single-mode transmission, low dispersion, high bandwidth, suitable for long-distance optical communication and most high-precision fiber optic sensing (e.g., FBG fiber grating demodulation systems).
- Multi-Mode Fiber (MMF): Typically 50\ \mu\text{m} or 62.5\ \mu\text{m} core diameter (e.g., OM2/OM3/OM4), primarily used for short-distance local data transmission or specific optical energy harvesting systems.
- Polarization-Maintaining Fiber (PMF): Such as Panda-type PMF, suitable for interferometric sensing systems or laser outputs requiring strict polarization state preservation.
- Bending Radius and Spatial Constraints:
- Standard general-purpose single-mode fiber is G.652D.
- If the cable route is within confined corners of a chassis or requires coiling with a small bending radius, use bend-insensitive fiber (e.g., G.657 A2 or B3 standard) with superior bend resistance.
Step 3: Determine the Fiber Connector Type and End-Face Polishing Method (Interface Compatibility and Return Loss Control)
The connector determines the physical compatibility and optical return loss quality of the patch cord with the light source, sensor, adapter plate, or demodulator’s physical port:
- Connector Mechanical Form Factor:
- FC: Round threaded metal structure, good vibration resistance, secure fastening. It is the standard mainstream interface for industrial instruments, fiber grating demodulators, and laboratory platforms.
- LC: Small form factor, push-pull connector, commonly used in high-density communication switches and optical modules.
- SC / ST: SC is a rectangular push-pull connector, ST is a round bayonet connector.
- Both ends can have the same connector type (e.g., FC-FC) or be customized as hybrid patch cords (e.g., FC-LC).
- End-Face Polishing Process (PC/UPC vs. APC):
- PC / UPC (Physical Contact / Ultra Physical Contact): Fiber end faces meet in a micro-spherical contact. Return Loss (RL) is typically \ge 50\text{ dB}. Connector housings are usually blue or black.
- APC (Angled Physical Contact): The end face is polished at an 8^\circ angle, causing reflected light to refract into the cladding and escape. Return Loss is typically \ge 60\text{ dB}. Connector housings are green. In fiber grating sensing and spectral measurements, APC (e.g., FC/APC) is often mandatory to prevent Fresnel reflections at the fiber end face from causing interference ghost peaks or damaging narrow linewidth lasers.
OFSCN® Official Typical Patch Cord Product Reference
Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) manufacturing lines offer various industrial-grade technical solutions based on the three-step logic described above:
1. Standard Communication and Laboratory Environments: OFSCN® Standard Fiber Patch Cord
Utilizes a PVC jacket and Kevlar structure, standard G.652D single-mode fiber, and FC/APC connectors by default, with an operating temperature range of -20\ ^\circ\text{C} to +50\ ^\circ\text{C}.
2. Heavy-Duty and Harsh Industrial Mechanical Environments: OFSCN® 3.0mm Steel Wire Rope Fiber Optic Patch Cord
Features a PE jacket, 0.45\text{ mm} stainless steel wire rope structure, and a double layer of 0.9\text{ mm} seamless stainless steel tubing. It incorporates OFSCN® G.657 bend-insensitive fiber, offering extremely high mechanical protection with tensile strength >1200\text{ N} and compressive strength >200\text{ MPa}. The operating temperature range is -40\ ^\circ\text{C} to +75\ ^\circ\text{C}.
3. Harsh Industrial High-Temperature Environments: OFSCN® 300℃ Fiber Optic Patch Cord
Employs a seamless stainless steel tube structure with 300\ ^\circ\text{C} polyimide-coated single-mode fiber, tolerating temperatures from -270\ ^\circ\text{C} to +300\ ^\circ\text{C}. It is specifically designed for optical signal transmission in demanding high and low-temperature industrial environments.
For complete technical specifications and additional temperature range options ( 120\ ^\circ\text{C} , 200\ ^\circ\text{C} , 700\ ^\circ\text{C} ), please refer to the official compilation: OFSCN® Fiber Optic Patch Cord Product Categories.
