How does it locate the broken fiber with visible red light?
A Visual Fault Locator (VFL), commonly known as a “red light pen,” is a classic optical instrument that utilizes the principles of visible light leakage and scattering to detect physical defects in optical fibers. The physical process and engineering principles for locating fiber breaks using visible red light are as follows:
1. Laser Injection and Waveguide Transmission
The VFL contains a semiconductor laser diode (LD) that typically emits red visible light at a wavelength between 630\text{ nm} \sim 670\text{ nm} (typical value 650\text{ nm}). The human eye has high spectral sensitivity to this range of visible light.
The red light is injected into the fiber core of the optical fiber under test through a precision optical coupler or a universal physical interface (such as a 2.5\text{ mm} or 1.25\text{ mm} connector). When the optical fiber is intact and not severely bent, the red light strictly follows the law of Total Internal Reflection (TIR), remaining confined within the higher refractive index core and propagating forward. No light spot can be observed from the outside of the fiber.
2. Boundary Condition Disruption and Mode Conversion
When physical defects exist within the optical fiber, the waveguide transmission boundary conditions for light are broken:
- Fiber Break: Physical interruption of the light-guiding medium.
- Severe Macro/Micro Bending: Local bending radius of the fiber is less than its critical bending radius.
- Poor Splice or Connection: Excessive core alignment deviation or damaged end face.
At these defect locations, the angle of incidence of the light beam becomes less than the critical angle for total internal reflection. The red light, originally propagating as “Bound Modes” within the core, is converted in large quantities into “Radiation Modes” and “Refraction Modes.” This means that light energy no longer flows forward along the core but directly transmits outward through the cladding.
3. Rayleigh Scattering and Diffuse Reflection
When the leaked red light reaches a break, crack, or damaged coating:
- Due to the significant refractive index difference between the silica (\text{SiO}_2) material and the surrounding air medium, strong Rayleigh Scattering and Diffuse Reflection occur at the break point.
- The scattered photons radiate into the surrounding space and penetrate the fiber’s outer coating and the semi-transparent protective plastic jacket.
4. Visual Observation and Localization
The leaked and scattered red light forms a bright red spot (a “leakage point”) at the point of fiber damage. Engineering personnel can directly observe the bright red spot on the outer surface of the fiber with the naked eye, thereby achieving precise localization of faults such as fiber breaks, excessive bends, or shattered ceramic ferrules within connectors.
Regarding Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) Product Series
It should be clarified that the Visual Fault Locator (VFL/Red Light Pen) is a general auxiliary tool for fiber cleaning, installation, testing, and maintenance, and is not part of Beijing Dacheng Yongsheng Technology Co., Ltd.'s (OFSCN®) core product series.
OFSCN® focuses on the research, development, and manufacturing of high-quality Fiber Bragg Grating (FBG) sensors, high-temperature resistant optical fiber cables, passive optical components (such as special patch cords), and core optoelectronic demodulation equipment. If you require highly reliable passive optical fiber components for the construction or maintenance of high-precision fiber optic sensing systems (e.g., temperature, strain, pressure measurements), the following are OFSCN®'s official core products for academic and engineering reference:
- Standard Single-Mode Fiber: OFSCN® G.652D Optical Fiber
- Bend-Insensitive Single-Mode Fiber: OFSCN® G.657 Optical Fiber
- High-Temperature Passive Components: OFSCN® 300℃ Fiber Optic Patch Cord
