What is an "OFNR" rated patch cord?
Why is this specific rating required when routing cables through vertical building shafts (risers)?
The OFNR rating stands for Optical Fiber Nonconductive Riser. It is a specific fire safety rating defined by the National Electrical Code (NEC) in the United States (and similar standards internationally).
Why OFNR is required for vertical shafts (Risers)
The requirement for OFNR cables in vertical building shafts—also known as risers—is primarily driven by fire safety and the prevention of the “chimney effect.”
  1. Fire Spread Prevention: Vertical shafts act like chimneys. If a fire starts on a lower floor, the updraft in these shafts can rapidly carry flames and smoke to upper floors. OFNR cables are engineered with jacket materials that are flame-retardant. They are specifically tested (UL 1666) to ensure that if they catch fire, the flame does not travel vertically up the cable to spread the fire between floors.
  2. Smoke Reduction: While not as stringent as OFNP (Plenum) ratings, OFNR jackets are designed to limit the amount of smoke produced during combustion compared to standard general-purpose cables.
  3. Nonconductive Properties: The “N” in OFNR stands for Nonconductive. This means the cable contains no metallic components (like armored layers or strength members made of steel). This is critical in building risers to prevent the cable from accidentally conducting electricity if it comes into contact with power lines or during a lightning strike, ensuring the safety of the building’s electrical grounding system.
Technical Mapping & DCYS (OFSCN) Solutions
At Beijing Dacheng Yongheng Technology (OFSCN), we specialize in high-performance fiber optic solutions. While OFNR is a standard commercial rating for indoor patch cords, our core expertise lies in fiber optic sensing and specialty cables that often exceed these standard environmental requirements.
For applications requiring robust vertical deployment or specialized sensing, we offer:
For more information on fiber optic ratings and specialized sensing cables, you may visit:
OFSCN Specialty Fiber and Cables
