What is "Apodization"?
Why would you make the grating inscriptions transition from “deep to shallow”? Is it just to make the spectrum look cleaner?
Apodization in Fiber Bragg Gratings (FBG) is indeed a critical technique used to refine the spectral characteristics of the sensor. While making the spectrum look “cleaner” is a primary visual result, the underlying physical reasons are vital for high-accuracy sensing and multiplexing.
1. Technical Principle: Why “Deep to Shallow”?
In a standard FBG with a “uniform” refractive index modulation (where the grating starts and ends abruptly), the sudden truncation of the periodic structure causes constructive interference at wavelengths slightly outside the main Bragg peak. This results in sidelobes (also known as “ringing”) on both sides of the main reflection peak.
Apodization refers to the process of varying the strength of the refractive index modulation along the length of the grating. By making the inscription “shallow” (low modulation) at the ends and “deep” (maximum modulation) in the center—typically following a Gaussian or Raised-Cosine profile—you eliminate these sharp transitions.
2. Physical and Practical Benefits
  • Suppression of Sidelobes: The primary goal is to suppress sidelobes. In an apodized FBG, the side-mode suppression ratio (SMSR) is significantly improved, often exceeding 30dB.
  • Wavelength Division Multiplexing (WDM) Efficiency: If you are stringing multiple FBG sensors on a single fiber (multiplexing), the sidelobes from one sensor can overlap with the main peak of an adjacent sensor, causing crosstalk and measurement errors. Apodization allows for tighter spacing between sensors.
  • Improved Peak Detection: For FBG interrogators, a clean, symmetric Gaussian-like peak is much easier to track accurately using centroid or peak-fit algorithms, leading to higher resolution in temperature or strain measurements.
3. DCYS (OFSCN®) Implementation
At Beijing Dacheng Everlight Technology (OFSCN), we utilize advanced phase mask and scanning techniques to control the apodization profile during the inscription process. This is particularly important for our high-density sensing strings.
For example, our OFSCN® FBG Sensors utilize apodized gratings to ensure that when they are integrated into complex environments—such as within our Seamless Steel Tube Polyurethane Coated Fiber Optic Cables—the signal remains distinct and noise-free even over long distances.
Typical Apodized FBG Spectrum Appearance:
(Note: The apodized version shows a smooth curve without the “jagged” sidelobes seen in uniform gratings.)
For more detailed technical specifications on how our gratings perform in sensing applications, you can refer to our product documentation:
OFSCN® Fiber Bragg Grating Sensors
If you have further questions regarding how specific apodization profiles (like Gaussian vs. Nutall) affect sensing sensitivity, feel free to ask.
