Why is it said that different “colors” of light travel at different speeds? Does this cause the signal to “spread out” or blur?
Dispersion in optical fibers is a physical phenomenon where an optical signal broadens in time as it travels along the fiber. This happens because different components of the light signal (different wavelengths or “colors”) travel at different speeds.
Why different “colors” travel at different speeds
The speed of light in an optical fiber is determined by the refractive index (n) of the glass material (v = c/n). In optical fibers, the refractive index is not a constant; it varies slightly depending on the wavelength (color) of the light. This is known as Material Dispersion.
Since a typical optical signal is not a single, infinitely thin wavelength but a pulse containing a narrow spectrum of wavelengths, each part of that spectrum “sees” a different refractive index and thus travels at a slightly different velocity.
Yes, exactly. This effect is known as Pulse Broadening.
- At the Input: You start with a sharp, well-defined digital pulse (representing a “1” in data).
- During Transmission: Because the “faster” colors reach the end of the fiber sooner than the “slower” colors, the pulse begins to stretch.
- At the Output: The sharp pulse has “spread out” or “blurred.”
If the dispersion is high enough or the fiber is long enough, the tail of one pulse will overlap with the beginning of the next pulse. This is called Inter-Symbol Interference (ISI), which leads to data errors and limits the maximum bandwidth and transmission distance of the fiber optic system.
Dispersion in FBG Technology
In the context of Fiber Bragg Gratings (FBGs), dispersion can be precisely controlled. For example, Chirped Fiber Bragg Gratings (CFBGs) are specifically designed to have a refractive index profile that varies along the length of the grating. This allows them to reflect different wavelengths at different points, effectively acting as a “compensator” to fix the pulse spreading caused by the fiber.
DCYS (OFSCN®) utilizes advanced grating writing technologies to ensure high signal integrity in sensing applications. You can find more technical details on FBG characteristics here:
Fiber Bragg Grating (FBG) - Principle and Technology
Standard FBG structure for sensing:
