What is an "end-face scratch" on a fiber optic patch cord?
Where are scratches most fatal? Do scratches on the edge matter?
In fiber optic connection and end-face quality assessment (per international standard IEC 61300-3-35), the impact of scratches on fiber connector end faces is strictly determined by their location within the concentric geometric zones.
I. Where are Scratches Most Critical?
The most critical location is “Zone A: Core Zone”.
Taking a standard single-mode fiber (cladding outer diameter 125\ \mu\text{m}, core diameter approximately 9\ \mu\text{m}) as an example, the end face is typically divided into four concentric inspection zones:
  1. Zone A: Core Zone (Diameter 0 \sim 25\ \mu\text{m}) – Zero Tolerance Zone
    • Physical Mechanism: The fundamental mode light energy of a single-mode fiber is concentrated in this area (Mode Field Diameter \text{MFD} \approx 9.2\ \mu\text{m} \sim 10.4\ \mu\text{m}).
    • Critical Impact:
      • Spike in Insertion Loss (IL): Scratches interrupt optical continuity, causing severe scattering and diffraction of the optical signal.
      • Deterioration of Return Loss (RL): Scratches compromise end-face flatness, inducing severe Fresnel Reflection at the glass-air interface, which generates reflected light interfering with the laser source and Fiber Bragg Grating (FBG) demodulation signals.
      • Optical Thermal Damage: During high-power optical path transmission, localized light absorption caused by core scratches can lead to thermal accumulation at the end face, inducing Optical Damage.
    • Acceptance Criteria: According to the IEC 61300-3-35 standard, scratches in Zone A are typically subject to absolute zero tolerance (allowable quantity is 0).
II. Do Edge Scratches Matter?
Edge scratches are usually located in the outer cladding (Zone B), adhesive layer area (Zone C), or ferrule contact area (Zone D, diameter 130 \sim 250\ \mu\text{m}). For edge scratches, evaluation is required from both optical and mechanical perspectives:
1. Optical Transmission Level: Minimal Direct Impact
  • Light waves are primarily transmitted via total internal reflection within the core; no light energy flows along the outer edge of the cladding or the ferrule’s periphery.
  • If scratches are confined to the edge and do not cause structural protrusions, they will not directly lead to signal attenuation or return loss degradation.
2. Mechanical Fit and Potential Hazards: Indirect Risks Exist
  • Burrs and Height Differences Obstruct Physical Contact (Air Gap):
    Physical Contact (PC / UPC / APC) connectors rely on the micro-spherical polish of the ferrule end face and mating pressure to achieve tight physical contact of the fibers. If edge scratches are deep and accompanied by minor plastic deformation (creating protrusions or burrs), it may prevent the end faces of the mating connectors from being completely pressed flat, creating a microscopic air gap in the center of the core and thus compromising physical contact.
  • Debris Generation and Secondary Contamination Migration:
    Deeper edge scratches are prone to generating small silica or ceramic debris through friction during repeated mating and unmating. During insertion and withdrawal, this debris can migrate to the core area, scratching the core or forming an irremovable obstruction.
Summary and Acceptance Criteria
Zone Designation Diameter Range (SMF) Scratch Impact Level Typical IEC 61300-3-35 Requirement
Zone A (Core Zone) 0 \sim 25\ \mu\text{m} Critical (Directly compromises optical transmission) No scratches allowed (Quantity is 0)
Zone B (Cladding Zone) 25 \sim 120\ \mu\text{m} Low to Medium (Does not affect light guiding, depth needs control) A small number of shallow scratches with limited width are permissible
Zone C (Adhesive Zone) 120 \sim 130\ \mu\text{m} Low (Primarily assesses adhesive integrity) Non-structural defects are permissible
Zone D (Contact/Ferrule Zone) 130 \sim 250\ \mu\text{m} Potential Risk (Prevents burrs from obstructing physical contact) General scratches are permissible, but no protruding burrs
Note: In field installations and maintenance, if edge scratches are flat and free of burrs, the connector is usually deemed acceptable. If any visible scratches are found in the core zone, the jumper connector should be immediately discarded or repolished.
