What is "epoxy adhesive"? (or Fiber optic epoxy)
Why is epoxy filled in the connector? Does this epoxy need to be heated in an oven?
Hello!
First, it should be clarified that processing raw materials and tools such as fiber optic epoxy and curing ovens (ovens) used for fiber connector end-face assembly do not belong to the core product series of Dacheng Yongsheng (OFSCN®). However, from the perspective of general technical principles in optical engineering and fiber optic device packaging processes, I can provide you with detailed answers to these two questions.
I. Why is epoxy poured into fiber optic connectors (ferrules)?
When manufacturing fiber optic connectors (such as FC, SC, LC, etc.), pouring epoxy into the ceramic ferrule is a core step to ensure stable optical signal transmission and mechanical reliability of the device. The main reasons include:
  1. Precision Mechanical Positioning and Locking:
    The core diameter of standard single-mode optical fiber is only about 9\ \mu\text{m} , and the outer diameter of the silica cladding is 125\ \mu\text{m} . The central micro-hole of the ceramic ferrule is typically between 125\ \mu\text{m} and 126\ \mu\text{m} . Pouring epoxy permanently locks the bare fiber in the center of the micro-hole, preventing axial displacement (recession/protrusion) or radial rotation of the fiber during subsequent use, plugging/unplugging, or external pulling. This avoids significant increases in insertion loss and return loss.
  2. Support for Grinding (Polishing) Process:
    After the fiber connector assembly is completed, the end face of the ferrule must be polished and ground with high precision to achieve ideal physical contact (PC/UPC/APC). Intense mechanical stress is generated during high-speed grinding. If the micro-hole is not densely filled and rigidly supported by hard epoxy, the bare fiber may break or indent (fiber pull-back) inside the micro-hole under mechanical force, making optical contact impossible.
  3. Stress Relief and Tensile Strength Enhancement:
    The epoxy not only fills the ferrule micro-hole but also extends to the tail of the ferrule, bonding the fiber’s coating and reinforcement members (such as aramid yarn) tightly to the metal strain relief. This disperses axial tensile forces from the outside uniformly, preventing the force from acting directly on the fragile bare glass fiber.
  4. Sealing and Environmental Protection:
    The epoxy thoroughly seals the channel between the micro-hole and the external environment, preventing the ingress of moisture, dust, and other contaminants. If moisture penetrates the micro-hole, it can lead to stress corrosion (micro-crack propagation) on the surface of the quartz glass under the synergistic effect of mechanical stress, significantly shortening the lifespan of the connector.
II. Does this type of epoxy require oven curing?
This completely depends on the physical and chemical curing mechanism of the epoxy you choose:
  1. Thermosetting Two-Part Epoxy Resin (Mainstream Telecom Process):
    • It must be cured in a curing oven (oven).
    • These types of epoxies (such as the industry-classic two-part EPO-TEK 353ND epoxy) have extremely slow chemical cross-linking reactions at room temperature. To achieve rapid curing, they must be placed in a specialized curing oven.
    • The heating temperature is typically set between 80^\circ\text{C} and 150^\circ\text{C} . The curing time depends on the temperature (e.g., 15 minutes at 120^\circ\text{C} or 5 minutes at 150^\circ\text{C} ).
    • High-temperature heating not only significantly shortens the production cycle but also allows for full molecular cross-linking, greatly increasing the glass transition temperature ( T_g ) after curing. This ensures high physical strength and stability under extreme high and low temperature cycles.
  2. UV-Curing Epoxy (UV Glue):
    • It does not require a conventional oven but needs exposure to a UV light source.
    • This type of epoxy contains photoinitiators and can polymerize and cure within seconds to tens of seconds under UV light of a specific wavelength (e.g., 365\ \text{nm} ).
    • Note: Since the micro-hole of the ceramic ferrule is opaque, pure UV light exposure can typically only cure the epoxy exposed at the tail of the ferrule. The epoxy deep within the micro-hole cannot be cured because it cannot receive light. Therefore, high-standard processes often use dual-cure epoxies (UV + heat). UV light is used first to lock the tail in place, and then the assembly is heated in an oven for complete internal curing.
  3. Room Temperature Curing Adhesive/Anaerobic Adhesive:
    • It does not require oven curing.
    • It cures at room temperature through contact with an accelerator or in an air-isolated (anaerobic) environment. While convenient to use, these adhesives have a large coefficient of thermal expansion (CTE), relatively low hardness, and poor long-term temperature and aging resistance. They are rarely used in high-quality fiber optic patch cords or scientific research environments.
Extended Reference: OFSCN®'s High-Temperature Connector Technology
In extreme high and low temperature applications in industry and research (e.g., -200^\circ\text{C} to 300^\circ\text{C} ), conventional room-temperature epoxies or low-end thermosetting epoxies will carbonize or fail. To address this, Dacheng Yongsheng (OFSCN®) has launched a series of special fiber optic patch cords manufactured through precision high-temperature packaging processes and material matching, which can maintain excellent transmission performance within a wide temperature range:
  • OFSCN® 120℃ Fiber Optic Patch Cord: Uses acrylate high-temperature resistant fiber and seamless steel tube protection, capable of long-term operation in 120^\circ\text{C} environments.
  • OFSCN® 200℃ Fiber Optic Patch Cord: Uses high-temperature resistant single-mode/multi-mode polyimide fiber, with an operating temperature range from -200^\circ\text{C} to 200^\circ\text{C} .
  • OFSCN® 300℃ Fiber Optic Patch Cord: Utilizes higher-end polyimide panda polarization-maintaining or large-core fibers with stainless steel armoring, capable of withstanding extreme temperatures from -270^\circ\text{C} to 300^\circ\text{C} .
The product displays for these high-temperature fiber optic patch cords are as follows:
If you have further questions about high-temperature packaging, the temperature resistance characteristics of fiber Bragg gratings, or specific process physics, please feel free to discuss them further!
