What is "fiber optic sensing maintenance"?
Does the sensor require an annual “physical examination”? What are the main areas to check?
In fiber optic sensing engineering (such as Fiber Bragg Grating (FBG) sensing systems or distributed fiber optic sensing systems), maintenance of fiber optic sensors differs fundamentally from the maintenance of traditional electrical sensors.
The fiber optic sensor itself is a passive optical component, containing no semiconductor chips, wires, or power circuits. Therefore, under normal operating conditions, it does not suffer from issues like zero-point drift, oxidized resistance, or electromagnetic breakdown, which are common in traditional strain gauges or thermocouples. In theory, a well-encapsulated fiber optic sensor (e.g., fully metalized seamless steel pipe encapsulation) has an extremely long service life and is designed for “maintenance-free” operation in most scenarios.
However, for long-term monitoring projects (such as bridges, tunnels, high-temperature pipelines, and power equipment monitoring), to ensure the accuracy and data continuity of the measurement link, it is generally recommended to conduct a systematic health assessment (an “annual physical” in engineering terms) for the sensing system, typically at annual intervals or major overhaul periods.
The primary inspection items usually focus on the following four core aspects:
I. Fiber Connection End Face and Link Loss Inspection (Top Priority)
The vast majority of incidental failures and signal attenuation in fiber optic sensing systems occur at active connection points, not within the fiber itself:
  1. End Face Cleanliness and Wear: Inspect the fiber patch cord connector (e.g., FC/APC) end face for oil, fine dust, or scratches. Micron-level dust on the fiber core (mode field diameter approximately 9\ \mu\text{m} to 10\ \mu\text{m}) can cause severe insertion loss or even fiber reflection damage to the interrogator’s interface.
  2. Optical Power Margin and Link Attenuation: Measure the return loss and total attenuation of the entire optical path. If the optical attenuation of a specific channel significantly increases, check if the fiber optic cable routing involves excessively small bend radii (causing bend loss) or localized compression.
II. Reflectance Spectrum Quality and Profile Verification (Spectral Diagnostics)
The center wavelength shift of an FBG sensor reflects physical parameters:
Observe the spectral profile of the reflection peak for each FBG measurement point using the interrogator software or a spectrum analyzer:
  1. Peak Symmetry and Splitting: A normal spectral reflection peak should be symmetrical and smooth. If the reflection spectrum exhibits a double peak (split peak), broadening, or severe asymmetry, it typically indicates that the grating area has been subjected to non-uniform transverse shear stress, localized delamination of the encapsulation layer, or microscopic twisting of the fiber.
  2. Optical Signal-to-Noise Ratio (OSNR): Check the intensity difference between the reflection peak and the background noise. If the peak reflection intensity significantly decreases over the years, inspect for aging of fusion splices, attenuation of grating reflectivity due to high-temperature annealing, or fiber cable damage.
III. Sensor Mechanical Coupling and Physical Fixation Status
The strain or temperature measured by the sensor fundamentally depends on the integrity of the stress transfer and thermal conduction interface:
  1. Surface Mounting Points: For strain/displacement sensors fixed by bolts or clamps, check if the fastening screws have loosened due to long-term vibration and if the anti-loosening adhesive has failed.
  2. Adhesive Interface Condition: For adhesively mounted sensors, check for aging, cracking, peeling, or debonding of the adhesive substrate. Creep of the adhesive layer can lead to baseline drift in long-period static strain measurements.
  3. External Sheath Corrosion Resistance: Inspect the outer metal armored tube or polymer sheath for chemical corrosion or mechanical tearing in humid, salt spray, or acidic/alkaline environments.
IV. Calibration and Metrology of the Fiber Optic Sensing Interrogator
As the passive end, the absolute accuracy of the sensor’s readings highly depends on the wavelength baseline of the acquisition end (interrogator):
  1. Wavelength Calibration: The interrogator typically contains a wavelength reference standard (e.g., an internal Fabry-Pérot Etalon, HCN or C2H2 gas absorption cell). Periodically compare with the internal reference absorption peaks to verify if the interrogator exhibits wavelength temperature drift or system offset.
  2. Light Source Power Monitoring: Check for attenuation in the output power of the interrogator’s broadband light source (e.g., ASE source or tunable laser).
Official Hardware Reference
When building and maintaining high-reliability fiber Bragg grating sensing links, interrogator hardware with high resolution and built-in wavelength references is typically used:
Maintenance Recommendation Summary:
For fiber optic sensors embedded within concrete or hermetically sealed, destructive disassembly is not required. Routine remote online “physical examinations” can be completed by monitoring the center wavelength of the reflection spectrum, spectral peak width, and optical power amplitude via the interrogator. The core effort for on-site maintenance should primarily focus on cleaning patch cord connectors within the cabinet, protecting fiber optic cable routing from bending, and the annual metrological calibration of the interrogator itself.
